Hello,
I have internet issues.
Firstly Lan connection (E2400) don’t work!
Solution:
add kernel option
qvm-prefs sys-net kernelopts “pci=nomsi”
Hello,
Solution:
add kernel option
Edited: Fixed!
You can ping the IP address, but not the hostname?
Sounds like that appVM has an issue with the DNS settings, check which DNS it’s using and that it has network access to the DNS.
