I have had this going on for quite some time, but I haven’t gotten around to asking about it until now.
I am running on a Framework 13 AMD version, and I am currently using the Intel AX210 card (which I used previously with great success on the old Intel 11th Gen mainboard before upgrading to the AMD Mainboard). So I assume the card is fine. Plus I generally have been working off of a Fedora 39 Live Session for the past couple months since this issue began, and I have never had any issue on Baremetal Fedora.
The Symptoms are simply a connection that barely works and seems to come in and out BUT the actual “wifi connection” never drops. Meaning I am connected constantly, but the connection just doesn’t transfer data very well. Ethernet connection to the same router works just fine. And connecting via wifi on my baremetal Fedora Session on the same laptop also is perfectly fine.
I have tried to check the journalctl logs on sys-net and sys-firewall, but there does not appear to be anything that might be indicative of an unusual issue there. Is there some other log I could check that might elucidate this issue? I don’t know much about how to diagnose this beyond those logs, but if anyone is willing to take some minutes to help, I am happy to look into anything that you might suggest!
Thanks!
