For some reason the installer (R4.0.4 & R3.2.1) does not detect the VT-x CPU extensions.
And even if I ignore the installer warning and continue, it doesn’t appear in the installed system.
The CPU, Xeon E5520, supports the extensions, so does the Dell board (I can add pics if needed)
Also when I cat /proc/cpuinfo it doesn’t appear?
Is this a problem with the Dell T3500 or do I need to add something to the Xen config?
Regards,
Craig
@shintaro69, try updating your BIOS, and then make sure that you have
virtualization enabled.
I cant speak to the Dell board, but you can (presumably) confirm this
with Dell.
