zupse
January 2, 2024, 12:55pm
1
added intel_pstate=enable to boot option but intel_pstate is still off and xenpm is still using acpi driver. Is the intel_pstate=enable boot option removed from qubes?
solene
January 2, 2024, 12:59pm
2
Which version of Qubes OS are you using?
solene
January 2, 2024, 2:06pm
4
You should try Qubes OS 4.2 which was released a few days ago. Hardware support is greatly enhanced.
intel_pstate won’t work in dom0:
opened 10:23PM - 12 Dec 18 UTC
T: bug
C: Xen
P: major
r4.1-buster-stable
hardware support
r4.1-bullseye-stable
r4.1-dom0-stable
needs diagnosis
pr submitted
r4.1-centos-stream8-cur-test
r4.1-bookworm-stable
r4.2-host-cur-test
affects-4.1
affects-4.2
### Qubes OS version:
<!-- (e.g., `R3.2`)
You can get it from the dom0 te… rminal with the command
`cat /etc/qubes-release`
Type below this line. -->
R4.0
### Affected component(s):
intel_pstate
acpi-cpufreq
xenpm
### Steps to reproduce the behavior:
<!-- Use single backticks (`) for in-line code snippets and
triple backticks (```) for code blocks.
Tested on:
- Lenovo T480s
- Lenovo X1 Carbon Gen. 6
- Huawei Matebook X Pro.
All with Intel i7-8550U.
Latest BIOS revisions for the respective systems as of Dec. 2018
Kernel: 4.19.2-3.pvops.qubes.x86_64.
EFI install.
In dom0, `sudo xenpm get-cpufreq-para`
### Expected behavior:
The processor is rated at 1.8 GHz (4.0 turbo), so we would expect to see appropriate scaling in that range, available frequencies from 1800000 - 4000000.
Further, we would expect to see `scaling_driver = intel_pstate`.
### Actual behavior:
The CPU frequencies do not scale correctly. Why?
Frequencies are pinned at 2 GHz max, 400 MHz min, across all cores.
# xenpm cpu-freq-para
cpu id : 0
affected_cpus : 0
cpuinfo frequency : max [2001000] min [400000] cur [2001000]
scaling_driver : acpi-cpufreq
scaling_avail_gov : userspace performance powersave ondemand
current_governor : ondemand
ondemand specific :
sampling_rate : max [10000000] min [10000] cur [20000]
up_threshold : 80
scaling_avail_freq : 2001000 2000000 1900000 1800000 1700000 1500000 1400000 1300000 1200000 1100000 1000000 800000 700000 600000 500000 *400000
scaling frequency : max [2001000] min [400000] cur [400000]
turbo mode : enabled
Confirmed with `watch -n1 "cat /proc/cpuinfo | grep \"[c]pu MHz\""`
`xenpm set-scaling-maxfreq` and `-minfreq` have no effect.
`xenpm get-cpufreq-states` shows 16 total/usable P-states.
Changing the governor to `performance` has no effect. Default is `ondemand`
`dmidecode` reports a max of 2 GHz on the Lenovos, and an apparently erroneous speed on the Huawei (~ 8 GHz).
# dmidecode | grep -i speed
Speed: 2400 MT/s
Configured Clock Speed: 2400 MT/s
Speed: 2400 MT/s
Speed: Unknown
Speed: Unknown
Speed: Unknown
Max Speed: 2000 MHz
Current Speed: 1800 MHz
The `scaling_driver` is legacy `acpi-cpufreq`. Interestingly, `intel_pstate` can be seen initializing during boot, but it does not take over handling anything. Attempting to `blacklist acpi-cpufreq` in `modprobe.d` has no effect.
# dmesg | grep pstate
[ 5.067624] intel_pstate: Intel P-state driver initializing
`/sys/devices/system/cpu/intel_pstate/` contains the expected attributes, but as mentioned in the "related issue" linked below, `no_turbo`, `num_pstates`, and `turbo_pct` error `Resource temporarily unavailable`.
`/sys/devices/system/cpu/intel_pstate/status` always returns `off`, and does not respond to `echo "active" >`. This behavior has been tested with various kernel command line parameters, including `intel_pstate=force`, `intel_pstate=disabled`, `intel_pstate=no_hwp`, `intel_pstate=enable` with no change in performance aside from `../cpu/intel_pstate/` attributes disappearing when `no_hwp` or `disabled` were in effect. Also tried `processor.ignore_ppc=1`.
Strangely, none of the appropriate attributes for `cpufreq` exist in `/sys/devices/system/cpu/cpu*/`.
# ls /sys/devices/system/cpu/cpu0/
acpi_cppc driver hotplug power topology
cache firmware_node node0 subsystem uevent
`lsmod | grep cpufreq` shows no results, trying to `modprobe acpi-cpufreq` or `cpufreq-xen` returns errors. `xen_acpi_processor` is loaded.
# modprobe acpi-cpufreq
modprobe: ERROR: could not insert 'acpi_cpufreq': No such device
# modprobe cpufreq-xen
modprobe: FATAL: Module cpufreq-xen not found in directory /lib/modules/4.19.2-3.pvops.qubes.x86_64
`cpupower frequency-info` is completely unresponsive, with zero information available about the processor.
analyzing CPU 0:
no or unknown cpufreq driver is active on this CPU
CPUs which run at the same hardware frequency: Not Available
CPUs which need to have their frequency coordinated by software: Not Available
maximum transition latency: Cannot determine or is not supported.
Not Available
available cpufreq governors: Not Available
Unable to determine current policy
current CPU frequency: Unable to call hardware
current CPU frequency: Unable to call to kernel
boost state support:
Supported: yes
Active: yes
Though it shouldn't have any effect, testing was attempted with `smt=on` and `off`, and `Hyperthreading` enabled/disabled in the BIOS appropriately.
Testing was also performed while toggling various BIOS settings.
- enable/disable `Intel SpeedStep`
- power settings at `Maximum Performance` vs. `Balanced`
It does not appear to be a thermal throttling issue, with idle ~ 37*C and under load ~60*C observed consistently.
`tlp` was tested with no effect on the frequency scaling, regardless of being enabled or disabled. `tlp-stat` yields minimal additional info, with what seems to be an outdated recommendation for the Lenovos to install `tp-smapi kernel modules`, that are in fact deprecated in favor of `thinkpad_acpi`, which appears to be active on the Thinkpads.
dmesg | grep thinkpad
[ 19.589434] thinkpad_acpi: ThinkPad ACPI Extras v0.26
[ 19.589439] thinkpad_acpi: http://ibm-acpi.sf.net/
[ 19.589440] thinkpad_acpi: ThinkPad BIOS N22ET50W (1.27 ), EC unknown
[ 19.589441] thinkpad_acpi: Lenovo ThinkPad T480s, model 20L7CTO1WW
[ 19.591883] thinkpad_acpi: radio switch found; radios are enabled
[ 19.591898] thinkpad_acpi: This ThinkPad has standard ACPI backlight brightness control, supported by the ACPI video driver
[ 19.591899] thinkpad_acpi: Disabling thinkpad-acpi brightness events by default...
[ 19.612278] thinkpad_acpi: rfkill switch tpacpi_wwan_sw: radio is unblocked
[ 19.643468] thinkpad_acpi: Standard ACPI backlight interface available, not loading native one
[ 19.674512] thinkpad_acpi: battery 1 registered (start 0, stop 100)
[ 19.674576] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/
`thermald` is not loaded.
### General notes:
https://www.kernel.org/doc/html/v4.12/admin-guide/pm/intel_pstate.html
- This link suggests removing `irqbalance` but I'm skeptical.
https://askubuntu.com/questions/1067866/ubuntu-18-04-steam-games-frame-rate-drop/1073353#1073353?newreg=c7c120f373da4effb7317104571cd573
- https://cateee.net/lkddb/web-lkddb/XEN_ACPI_PROCESSOR.html
Regarding xen_acpi_processor: "It also registers itself as the SMM so that other drivers (such as ACPI cpufreq scaling driver) will not load."
How could `lsmod` report `xen_acpi_processor` as loaded but `xenpm` shows the scaling driver `acpi-cpufreq` ? This might make sense as to the missing `/sys/devices/.../cpufreq` entries.
- The following exchange is dubious at best, the final post gets down to the point of disabling intel microcode. They also suggest the use of `msr-tools`, but that really shouldn't be necessary.
https://bbs.archlinux.org/viewtopic.php?id=231077
- This is good work, but in my opinion, running a script every few seconds in dom0 isn't a legitimate fix.
https://github.com/erpalma/lenovo-throttling-fix
### Related issues:
https://github.com/QubesOS/qubes-issues/issues/4491
https://github.com/QubesOS/qubes-issues/issues/450
You can enable the HWP support in Xen instead. It’s enabled by default in Qubes OS 4.2, for Qubes OS 4.1 you can add cpufreq=xen:hwp Xen command line option in GRUB.
zupse
January 2, 2024, 2:27pm
6
I tried HWP but it is worse than the acpi driver for me. Why intel_pstate won’t work?
Read the comment in my link.
