Remarks
Product specifications: Intel NUC11PAKi5.
Secure Boot needs to be disabled: F2 then
Setup > Boot > Secure Boot. - Only UEFI is available. Legacy BIOS is not available in NUC11. (Intel docs)
Qubes OS releases
Installation media: USB thumbdrive.
- R4.0.4: the machine rebooted before the installer became visible.
- R4.1-alpha20201014: the machine rebooted before the installer became visible.
- R4.1-beta1: installation OK. Performed a default installation (with Whonix).
Testing R4.1-beta1
Display at native resolution (2650x1440) OK
Wired network OK
Sound via HDMI OK
Sound via headphones in front JACK not OK, no output device is available. (That works fine with Tails 4.19.)
WiFi seems OK (but I haven’t actually established a connection)
USB keyboard and mouse OK (Note: no
sys-usbwas created by the installer, I didn’t add done either at this point.) -
Bluetooth, I can’t find it, not OK
IR receiver, I can’t find it either, not OK
Microphone OK
None yet. I’m still testing and will edit this post when ready. In the meantime, if you have questions, I’ll do my best to answer
