Intel i9-9900k; Gigabyte Z390 Aorus Ultra
layout:
  'hcl'
type:
  'Desktop'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  Gigabyte Technology Co., Ltd.
model: |
  Z390 AORUS ULTRA
bios: |
  F11
cpu: |
  Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
cpu-short: |
  FIXME
chipset: |
  Intel Corporation 8th/9th Gen Core 8-core Desktop Processor Host Bridge/DRAM Registers [Coffee Lake S] [8086:3e30] (rev 0d)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation CoffeeLake-S GT2 [UHD Graphics 630] [8086:3e98] (rev 02) (prog-if 00 [VGA controller])
  NVIDIA Corporation TU104 [GeForce RTX 2070 SUPER] [10de:1ec7] (rev a1) (prog-if 00 [VGA controller])
  NVIDIA Corporation GA106 [GeForce RTX 3060 Lite Hash Rate] [10de:2504] (rev a1) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Cannon Lake PCH CNVi WiFi [8086:a370] (rev 10)
  Intel Corporation Ethernet Connection (7) I219-V [8086:15bc] (rev 10)
memory: |
  130912
scsi: |
  ST320LT009-9WC14 Rev: DEMA
usb: |
  3
certified:
  'no'
versions:
  - works:
      'yes'
    qubes: |
      R4.2.4
    xen: |
      4.17.5
    kernel: |
      6.12.39-1
    remark: |
      FIXME
    credit: |
      FIXAUTHOR
    link: |
      FIXLINK
Remarks
After each attempt at installing Qubes the “Templates Configuration” menu had all of it’s options greyed out.
After reinstalling the OS a number of times with both 4.2.4 and 4.3.0 rc1 I gave up on getting this menu to work and went ahead with the install using 4.2.4.
Once the setup was finished and I was logged in there were no template qubes or service qubes installed, I resolved this by mounting my install USB and installing the Fedora template from the Packages folder.
Since the manual template installation I have had no issues and I can confirm the following features are working:
  • Networking using the built-in network card with Network Manager (Using a static IP and custom dns)
  • GPU passthrough to a Fedora 21 standalone qube
  • Single-monitor video via the iGPU
  • Audio, using both the built-in soundcard and a USB DAC
  • SATA HDD as the boot device
  • General browsing with firefox
Notes:
  • There’s no PS/2 port so a USB keyboard must be used
  • Video playback in firefox stutters slightly
Hardware:
  • CPU: Intel i9-9900k
  • Motherboard: Gigabyte Aorus Ultra
  • RAM: 4x 32gb DDR4 Corsair Vengeance LPX
  • Dedicated GPU 1: Nvidia RTX 2070 Super
  • Dedicated GPU 2: Nvidia RTX 3060
IOMMU grouping via lspci:
00:00.0 Host bridge: Intel Corporation 8th/9th Gen Core 8-core Desktop Processor Host Bridge/DRAM Registers [Coffee Lake S] (rev 0d)
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 0d)
00:01.1 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x8) (rev 0d)
00:02.0 VGA compatible controller: Intel Corporation CoffeeLake-S GT2 [UHD Graphics 630] (rev 02)
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10)
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
00:14.3 Network controller: Intel Corporation Cannon Lake PCH CNVi WiFi (rev 10)
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
00:17.0 SATA controller: Intel Corporation Cannon Lake PCH SATA AHCI Controller (rev 10)
00:1b.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #17 (rev f0)
00:1b.4 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #21 (rev f0)
00:1c.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #1 (rev f0)
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Z390 Chipset LPC/eSPI Controller (rev 10)
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
00:1f.5 Serial bus controller: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (7) I219-V (rev 10)
01:00.0 VGA compatible controller: NVIDIA Corporation TU104 [GeForce RTX 2070 SUPER] (rev a1)
01:00.1 Audio device: NVIDIA Corporation TU104 HD Audio Controller (rev a1)
01:00.2 USB controller: NVIDIA Corporation TU104 USB 3.1 Host Controller (rev a1)
01:00.3 Serial bus controller: NVIDIA Corporation TU104 USB Type-C UCSI Controller (rev a1)
02:00.0 VGA compatible controller: NVIDIA Corporation GA106 [GeForce RTX 3060 Lite Hash Rate] (rev a1)
02:00.1 Audio device: NVIDIA Corporation GA106 High Definition Audio Controller (rev a1)
04:00.0 Non-Volatile memory controller: Micron/Crucial Technology P1 NVMe PCIe SSD[Frampton] (rev 03)
06:00.0 Non-Volatile memory controller: Micron/Crucial Technology P2 [Nick P2] / P3 / P3 Plus NVMe PCIe SSD (DRAM-less) (rev 01)
HCL-Gigabyte-Z390-Aorus-Ultra.yaml (1.2 KB)
After further testing I’ve discovered that the installation issues were caused by a faulty USB stick, and after buying a new one I was able to install it with no issues.
All of previously confirmed features still work, and I can now confirm that an M.2 SSD can be used as a boot device for this configuration.
