cd qubes-wayland && meson setup build && cd build && meson compile
The Meson build system
Version: 1.3.2
Source dir: /home/user/qubes-wayland
Build dir: /home/user/qubes-wayland/build
Build type: native build
Project name: qubes-compositor
Project version: 0.0.1
C compiler for the host machine: ...
C linker for the host machine: cc ld.bfd 2.40-14
Host machine cpu family:
Host machine cpu:
Library dl found: YES
Library qubesdb found: YES
Found pkg-config: YES (/usr/bin/pkg-config) 1.9.5
Did not find CMake 'cmake'
Found CMake: NO
Run-time dependency wayland-protocols found: NO (tried pkgconfig and cmake)
Looking for a fallback subproject for the dependency wayland-protocols
meson.build:64:17: ERROR: Neither a subproject directory nor a wayland-protocols.wrap file was found.
A full log can be found at /home/user/qubes-wayland/build/meson-logs/meson-log.txt
Is there something wrong?
The log file says:
Called: `/usr/bin/pkg-config --modversion wayland-protocols` -> 1
stderr:
Package wayland-protocols was not found in the pkg-config search path.
Perhaps you should add the directory containing `wayland-protocols.pc'
to the PKG_CONFIG_PATH environment variable
Package 'wayland-protocols', required by 'virtual:world', not found
CMake binary for host machine is not cached
CMake binary missing from cross or native file, or env var undefined.
Trying a default CMake fallback at cmake
Found CMake: NO
CMake binary for machine host machine not found. Giving up.
Found CMake: /usr/bin/cmake (3.27.7)
Is still something wrong?
There is no package wayland-protocols installable in fedora.
That was a spelling mistake, sorry. Should be “now”. The packages were already installed. There is still the wayland-protocols error. What could I do?
Okay, now wayland-protocols work, but I had also to install wlroots and wlroots-devel. Now the problem is, that it needs an older version of wlroots, but it is not available in fedora 39:
Run-time dependency wayland-protocols found: YES 1.34
Build-time dependency wayland-scanner found: YES 1.22.0
Program /usr/bin/wayland-scanner found: YES (/usr/bin/wayland-scanner)
Dependency wlroots found: NO found 0.17.3 but need: '<0.17.0' ; matched: '>=0.16.0'
Run-time dependency wlroots found: NO (tried pkgconfig and cmake)
Submodule 'subprojects/wlroots' (git+ssh://git@gitlab.freedesktop.org/wlroots/wlroots.git) registered for path './'
Cloning into '/home/user/.local/share/Trash/files/qubes-wayland.4/qubes-wayland/subprojects/wlroots'...
git@gitlab.freedesktop.org: Permission denied (publickey).
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
fatal: clone of 'git+ssh://git@gitlab.freedesktop.org/wlroots/wlroots.git' into submodule path '/home/user/.local/share/Trash/files/qubes-wayland.4/qubes-wayland/subprojects/wlroots' failed
Failed to clone 'subprojects/wlroots'. Retry scheduled
Failed to clone 'subprojects/wlroots' a second time, aborting
meson.build:119:17: ERROR: git submodule failed to init
A full log can be found at /home/user/.local/share/Trash/files/qubes-wayland.4/qubes-wayland/build/meson-logs/meson-log.txt
INFO: calculating backend command to run: /usr/bin/ninja
[3/14] Generating Build Rust code with a custom command
FAILED: libqubes_gui_rust.a
/bin/sh -- /home/user/qubes-wayland/./build_rust.sh libqubes_gui_rust.d . libqubes_gui_rust.a.p .. release
error: failed to get `qubes-castable` as a dependency of package `qubes-gui-rust-parts v0.0.1 (/home/user/qubes-wayland)`
Caused by:
failed to load source for dependency `qubes-castable`
Caused by:
Unable to update /home/user/qubes-wayland/gui-rust/qubes-castable
Caused by:
failed to read `/home/user/qubes-wayland/gui-rust/qubes-castable/Cargo.toml`
Caused by:
No such file or directory (os error 2)
[5/14] Compiling C object qubes-compositor.p/cbits_qubes_allocator.c.o
ninja: build stopped: subcommand failed.
In this case there is an error with access rights to a gitlab.freedesktop.org repository:
Cloning into 'qubes-wayland'...
remote: Enumerating objects: 2455, done.
remote: Counting objects: 100% (580/580), done.
remote: Compressing objects: 100% (218/218), done.
remote: Total 2455 (delta 423), reused 498 (delta 353), pack-reused 1875
Receiving objects: 100% (2455/2455), 505.00 KiB | 5.61 MiB/s, done.
Resolving deltas: 100% (1773/1773), done.
Submodule 'gui-rust' (https://github.com/QubesOS/gui-rust.git) registered for path 'gui-rust'
Submodule 'subprojects/wlroots' (git+ssh://git@gitlab.freedesktop.org/wlroots/wlroots.git) registered for path 'subprojects/wlroots'
Cloning into '/home/user/qubes-wayland/gui-rust'...
remote: Enumerating objects: 1604, done.
remote: Counting objects: 100% (40/40), done.
remote: Compressing objects: 100% (28/28), done.
remote: Total 1604 (delta 11), reused 31 (delta 8), pack-reused 1564
Receiving objects: 100% (1604/1604), 782.07 KiB | 5.75 MiB/s, done.
Resolving deltas: 100% (644/644), done.
Cloning into '/home/user/qubes-wayland/subprojects/wlroots'...
The authenticity of host 'gitlab.freedesktop.org (147.28.146.59)' can't be established.
ED25519 key fingerprint is SHA256:i4LwjlmsgSrc3aWq3aVaDa8VQs6Fqq4nRBuFdZ6A1tE.
This key is not known by any other names
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
Warning: Permanently added 'gitlab.freedesktop.org' (ED25519) to the list of known hosts.
fatal: clone of 'git+ssh://git@gitlab.freedesktop.org/wlroots/wlroots.git' into submodule path '/home/user/qubes-wayland/subprojects/wlroots' failed
Submodule path 'gui-rust': checked out 'a545f4c7a49c2cce70088bcec84e9a2c6174bc40'
Submodule path 'subprojects/wlroots': checked out '0a32b5a74db06a27bee55a47205951bb277a9657'
