I am trying to install the onlykey-app snap in the vault VM. My vault AppVM is based on a fedora 34 template. The snap is installed in the template VM. The application shows up in the installed Applications for the qube, however even when it is available in that list, it doesn’t appear to run.
I understand in the documentation it says to install the snaps in the AppVM. However with the vault VM not having network access, how would this be done? Should the installed files in the template be copied to the app vm? Thank you for your responses.
