Apologies if this isn’t the correct forum to post to.
Has anyone here installed and run Ruby on Fedora 38 on their Qubes machine?
I’ve been trying to, having attempted it using both this fedora guide and the official ruby guide, including using the fedora guide on a fresh fedora standalone.
Both ruby and rails install without a complaint however when I run rails new app, I get a myriad of permissions errors, often asking me to grant permissions and when I do, it just ends up with another issue.
An example of an error I get is:
$ rails new app
create
create README.md
create Rakefile
create .ruby-version
create config.ru
create .gitignore
create .gitattributes
create Gemfile
run git init -b main from "."
Initialized empty Git repository in /home/user/Documents/app/.git/
create app
create app/assets/config/manifest.js
create app/assets/stylesheets/application.css
create app/channels/application_cable/channel.rb
create app/channels/application_cable/connection.rb
create app/controllers/application_controller.rb
create app/helpers/application_helper.rb
create app/jobs/application_job.rb
create app/mailers/application_mailer.rb
create app/models/application_record.rb
create app/views/layouts/application.html.erb
create app/views/layouts/mailer.html.erb
create app/views/layouts/mailer.text.erb
create app/assets/images
create app/assets/images/.keep
create app/controllers/concerns/.keep
create app/models/concerns/.keep
create bin
create bin/rails
create bin/rake
create bin/setup
create Dockerfile
create .dockerignore
create bin/docker-entrypoint
create config
create config/routes.rb
create config/application.rb
create config/environment.rb
create config/cable.yml
create config/puma.rb
create config/storage.yml
create config/environments
create config/environments/development.rb
create config/environments/production.rb
create config/environments/test.rb
create config/initializers
create config/initializers/assets.rb
create config/initializers/content_security_policy.rb
create config/initializers/cors.rb
create config/initializers/filter_parameter_logging.rb
create config/initializers/inflections.rb
create config/initializers/new_framework_defaults_7_1.rb
create config/initializers/permissions_policy.rb
create config/locales
create config/locales/en.yml
create config/master.key
append .gitignore
create config/boot.rb
create config/database.yml
create db
create db/seeds.rb
create lib
create lib/tasks
create lib/tasks/.keep
create lib/assets
create lib/assets/.keep
create log
create log/.keep
create public
create public/404.html
create public/422.html
create public/500.html
create public/apple-touch-icon-precomposed.png
create public/apple-touch-icon.png
create public/favicon.ico
create public/robots.txt
create tmp
create tmp/.keep
create tmp/pids
create tmp/pids/.keep
create tmp/cache
create tmp/cache/assets
create vendor
create vendor/.keep
create test/fixtures/files
create test/fixtures/files/.keep
create test/controllers
create test/controllers/.keep
create test/mailers
create test/mailers/.keep
create test/models
create test/models/.keep
create test/helpers
create test/helpers/.keep
create test/integration
create test/integration/.keep
create test/channels/application_cable/connection_test.rb
create test/test_helper.rb
create test/system
create test/system/.keep
create test/application_system_test_case.rb
create storage
create storage/.keep
create tmp/storage
create tmp/storage/.keep
remove config/initializers/cors.rb
remove config/initializers/new_framework_defaults_7_1.rb
run bundle install
Fetching gem metadata from https://rubygems.org/...........
Resolving dependencies...
Using rake 13.1.0
Fetching base64 0.2.0
Fetching bigdecimal 3.1.4
Retrying download gem from https://rubygems.org/ due to error (2/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/base64-0.2.0.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (3/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/base64-0.2.0.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (2/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/bigdecimal-3.1.4.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (4/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/base64-0.2.0.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (3/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/bigdecimal-3.1.4.gem`. It is likely that you need to grant write permissions for that path.
Using concurrent-ruby 1.2.2
Using connection_pool 2.4.1
Using ruby2_keywords 0.0.5
Using minitest 5.20.0
Fetching mutex_m 0.2.0
Retrying download gem from https://rubygems.org/ due to error (4/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/bigdecimal-3.1.4.gem`. It is likely that you need to grant write permissions for that path.
Using builder 3.2.4
Using erubi 1.12.0
Fetching racc 1.7.3
Retrying download gem from https://rubygems.org/ due to error (2/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/mutex_m-0.2.0.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (3/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/mutex_m-0.2.0.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (4/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/mutex_m-0.2.0.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (2/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/racc-1.7.3.gem`. It is likely that you need to grant write permissions for that path.
Using crass 1.0.6
Using rack 3.0.8
Using nio4r 2.5.9
Using websocket-extensions 0.1.5
Using zeitwerk 2.6.12
Using timeout 0.4.1
Using marcel 1.0.2
Using mini_mime 1.1.5
Fetching date 3.3.4
Retrying download gem from https://rubygems.org/ due to error (3/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/racc-1.7.3.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (4/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/racc-1.7.3.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (2/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/date-3.3.4.gem`. It is likely that you need to grant write permissions for that path.
Fetching public_suffix 5.0.3
Retrying download gem from https://rubygems.org/ due to error (3/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/date-3.3.4.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (2/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/public_suffix-5.0.3.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (4/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/date-3.3.4.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (3/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/public_suffix-5.0.3.gem`. It is likely that you need to grant write permissions for that path.
Fetching bindex 0.8.1
Retrying download gem from https://rubygems.org/ due to error (4/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/public_suffix-5.0.3.gem`. It is likely that you need to grant write permissions for that path.
Fetching msgpack 1.7.2
Retrying download gem from https://rubygems.org/ due to error (2/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/bindex-0.8.1.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (3/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/bindex-0.8.1.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (4/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/bindex-0.8.1.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (2/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/msgpack-1.7.2.gem`. It is likely that you need to grant write permissions for that path.
Using bundler 2.4.10
Fetching matrix 0.4.2
Retrying download gem from https://rubygems.org/ due to error (3/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/msgpack-1.7.2.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (2/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/matrix-0.4.2.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (4/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/msgpack-1.7.2.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (3/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/matrix-0.4.2.gem`. It is likely that you need to grant write permissions for that path.
Fetching regexp_parser 2.8.2
Retrying download gem from https://rubygems.org/ due to error (4/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/matrix-0.4.2.gem`. It is likely that you need to grant write permissions for that path.
Using stringio 3.0.9
Using io-console 0.6.0
Using webrick 1.8.1
Using thor 1.3.0
Fetching rexml 3.2.6
Retrying download gem from https://rubygems.org/ due to error (2/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/regexp_parser-2.8.2.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (3/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/regexp_parser-2.8.2.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (2/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/rexml-3.2.6.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (4/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/regexp_parser-2.8.2.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (3/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/rexml-3.2.6.gem`. It is likely that you need to grant write permissions for that path.
Fetching rubyzip 2.3.2
Retrying download gem from https://rubygems.org/ due to error (4/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/rexml-3.2.6.gem`. It is likely that you need to grant write permissions for that path.
Fetching websocket 1.2.10
Retrying download gem from https://rubygems.org/ due to error (2/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/rubyzip-2.3.2.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (3/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/rubyzip-2.3.2.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (2/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/websocket-1.2.10.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (4/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/rubyzip-2.3.2.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (3/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/websocket-1.2.10.gem`. It is likely that you need to grant write permissions for that path.
Fetching sqlite3 1.6.8 (x86_64-linux)
Retrying download gem from https://rubygems.org/ due to error (4/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/websocket-1.2.10.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (2/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/sqlite3-1.6.8-x86_64-linux.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (3/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/sqlite3-1.6.8-x86_64-linux.gem`. It is likely that you need to grant write permissions for that path.
Retrying download gem from https://rubygems.org/ due to error (4/4): Bundler::PermissionError There was an error while trying to write to `/usr/share/gems/cache/sqlite3-1.6.8-x86_64-linux.gem`. It is likely that you need to grant write permissions for that path.
Bundler::PermissionError: There was an error while trying to write to
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/shared_helpers.rb:105:in
`rescue in filesystem_access'
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/shared_helpers.rb:102:in
`filesystem_access'
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/rubygems_integration.rb:483:in
`block in download_gem'
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/retry.rb:40:in `run'
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/retry.rb:30:in `attempt'
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/rubygems_integration.rb:474:in
`download_gem'
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/source/rubygems.rb:484:in
`download_gem'
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/source/rubygems.rb:446:in
`fetch_gem'
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/source/rubygems.rb:430:in
`fetch_gem_if_possible'
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/source/rubygems.rb:158:in
`install'
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/installer/gem_installer.rb:54:in
`install'
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/installer/gem_installer.rb:16:in
`install_from_spec'
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/installer/parallel_installer.rb:156:in
`do_install'
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/installer/parallel_installer.rb:147:in
`block in worker_pool'
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/worker.rb:62:in `apply_func'
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/worker.rb:57:in `block in
process_queue'
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/worker.rb:54:in `loop'
`process_queue'
/usr/share/gems/gems/bundler-2.4.10/lib/bundler/worker.rb:90:in `block (2
levels) in create_threads'
An error occurred while installing base64 (0.2.0), and Bundler cannot
continue.
In Gemfile:
rails was resolved to 7.1.1, which depends on
actioncable was resolved to 7.1.1, which depends on
actionpack was resolved to 7.1.1, which depends on
actionview was resolved to 7.1.1, which depends on
rails-dom-testing was resolved to 2.2.0, which depends on
activesupport was resolved to 7.1.1, which depends on
base64
run bundle lock --add-platform=x86_64-linux
Writing lockfile to /home/user/Documents/app/Gemfile.lock
run bundle binstubs bundler
Could not find rails-7.1.1, sprockets-rails-3.4.2, sqlite3-1.6.8-x86_64-linux,
puma-6.4.0, importmap-rails-1.2.3, turbo-rails-1.5.0, stimulus-rails-1.3.0,
jbuilder-2.11.5, bootsnap-1.17.0, debug-1.8.0, web-console-4.2.1,
capybara-3.39.2, selenium-webdriver-4.15.0, sprockets-4.2.1, msgpack-1.7.2,
bindex-0.8.1, addressable-2.8.5, matrix-0.4.2, regexp_parser-2.8.2, xpath-3.2.0,
rexml-3.2.6, rubyzip-2.3.2, websocket-1.2.10, base64-0.2.0, bigdecimal-3.1.4,
drb-2.2.0, mutex_m-0.2.0, rdoc-6.6.0, public_suffix-5.0.3, racc-1.7.3,
date-3.3.4, net-protocol-0.2.2, psych-5.1.1.1 in locally installed gems
rails importmap:install
Could not find rails-7.1.1, sprockets-rails-3.4.2, sqlite3-1.6.8-x86_64-linux, puma-6.4.0, importmap-rails-1.2.3, turbo-rails-1.5.0, stimulus-rails-1.3.0, jbuilder-2.11.5, bootsnap-1.17.0, debug-1.8.0, web-console-4.2.1, capybara-3.39.2, selenium-webdriver-4.15.0, sprockets-4.2.1, msgpack-1.7.2, bindex-0.8.1, addressable-2.8.5, matrix-0.4.2, regexp_parser-2.8.2, xpath-3.2.0, rexml-3.2.6, rubyzip-2.3.2, websocket-1.2.10, base64-0.2.0, bigdecimal-3.1.4, drb-2.2.0, mutex_m-0.2.0, rdoc-6.6.0, public_suffix-5.0.3, racc-1.7.3, date-3.3.4, net-protocol-0.2.2, psych-5.1.1.1 in locally installed gems
Run `bundle install` to install missing gems.
rails turbo:install stimulus:install
I’ve been at this for a while now and there doesn’t seem to be many people talking about it so I thought maybe it was a Qubes thing (perhaps affecting permissions).
