Installing Qubes - Unable to reset PCI Device
I’m trying to install Qubes 4.1 on a Dell Latitude 5590 which has an ethernet port. The install process goes fine, but after everything has completed (before logging in) I get the following error message:
['/usr/bin/qvm-start', 'sys-firewall'] failed:
stdout: ""
stderr: "Start failed: internal error: Unable to reset PCI device 0000:00:1f:6: no
FLR, PM reset or bus reset available, see /var/log/libvirt/libxl/libxl-driver.log
for details
When I get to the desktop I have no ethernet or wifi. The lights on the ethernet port on the laptop are blinking and I confirmed it worked when running Windows. Wifi is not strictly necessary but I do need internet.
Does anybody know what the issue might be?
Is sys-net able to start?
It might be an issue with the devices passed to sys-net.
It looks like your device controller is attached to sys-firewall which is wrong.
@anon40243023 When I try to start up a disposable VM, Qubes tries to also start both sys-net and sys-firewall. I get 3 error messages saying that none of the VM’s can be started “Unable to reset PCI device”.
@enmus Do you know how to fix it? When setting up Qubes I did check the box to create sys-usb. I did not check the box to use sys-net for both usb and networking.
Is there something I have to change in the BIOS maybe?
First, check that is actually the case:
$ qvm-pci ls sys-firewall
If there is indeed a controller attached to sys-firewall, detach it:
$ qvm-pci detach sys-firewall [BACKEND:DEVICE_ID]
The [BACKEND:DEVICE_ID] looks something like this: dom0:0x_xx.x
Depending on your case, you may want to attach the extra controller to sys-net:
$ qvm-pci attach sys-net dom0:0x_xx.x
You can start with checking the devices tab in sys-net settings, it could be your ethernet or wireless devices that fail to initialize.
When you know the device name/model of 00:1f:6 you can confirm you have the correct driver/firmware.
The dmesg command i dom0 might also give you some useful information.
When I run qvm-pci ls sys-firewall I get the following output:
BACKEND:DEVID DESCRIPTION USED BY
If I run qvm-pci ls sys-net I get:
dom0:00_14.3 Network controller: Intel Corporation WIreless-AC 9560 [Jefferson Peak] sys-net
dom0:00_1f.6 Ethernet controller: Intel Corporation Ethernet Connection (7) I219-LM sys-net
Trying to start sys-net from the terminal I get:
Start failed: internal error: Unable to reset PCI device 0000:00:1f.6: no FLR, PM reset or bus reset available, see /var/log/libvirt/libxl/libxl-driver.log for details
Looking at the that log I get this:
libxl: libxl_pci.c:1489:libxl__device_reset: The kernel doesn't support reset from sysfs for PCI device 0000:00:14.0
So I assume it’s a kernel issue? This is laptop is a few years old so I assumed the kernel used in 4.1 would support this hardware. Sorry I’m out of my depth here…
Edit: also ran sudo dmesg in dom0 and I get a wall of text. What am I looking for?
Try to set
qvm-prefs sys-net virt_mode pv
reboot just in case and try to start sys-net.
Also. you can try
qvm-pci attach --persistent sys-net dom0:00_1f.6 -o no-strict-reset=true
Hi, had the same issue on a dell latitude 5440,
I have disable the 00_1f.6 (ethernet) bus on sys_net qubes parameters → devices,
and now it works, with wifi obviously I can’t use ethernet
Yes this was my issue by installing Q4.2.1, I resolved it by:
Qube Manager
SYS-NET / Settings /
TAB- Devices (there look for the PCI named and correlated to your error)
AVAILABLE DEVICES:
in my case:
01:00.1 Ethernet Controller Realtek … …
Select that from Left side and > put it on the right side
APPLY
OK
Wifi and Etehrnet working
This worked for me, had to restart and then the sys-firewall, and sys-net qubes came up automatically and the network devices functioned correctly.
Just did this a moment ago. You can do this through the GUI - Find the domU, select the device, see the button at bottom of dialog, and change the settings.
