I’m trying to install qubes onto a 1TB Partition, but I can’t even get close to the installer. I have no experience with this OS so I’m pretty clueless right now.
First, it got stuck on this stage for a long time.
Overall, I am really confused at what’s going on. My hardware is an AMD Radeon 5600 XT, along with a Ryzen 7 3700X. I have 32GB of memory @ 3600GHz, a beefy 750W psu, a 4TB hard drive, and a 512GB NVME SSD.
Is it my hardware? What can I do to resolve this issue?
Yes. I tried both options, those screenshots were from the kernel latest one. The R4.1.2 w/o kernel-latest stuck at the first screenshot. (Could’ve moved on if i waited longer, not sure)
Both of them seem to have the same issues where they stall at this stage.
EDIT:
Not sure if this means anything, but I have a SSD (Fully windows), and then a HDD, which has a partition used by windows, as well as a blank partition that i plan to put qubes on (1TB). It’s just weird cause it seems like its accessing the NVME, which is the SSD. Not sure if this is part of the problem.
