See the screenshot for what went wrong. What can I do here?
Try to update the template of your dom0 update proxy qube, then update dom0 and restart the system.
After this try to install the qubes-dist-upgrade package again.
Update of whonix-gw-16 template failed
Function: pkg.uptodate
Result: False
Comment: E: Release file for tor+https://deb.whonix.org/dists/bullseye/InRelease is expired (invalid since 68d 17h 29min 47s). Updates for this repository will not be applied.
Started: 07:46:22.812409
Duration: 16704.894 ms
Changes:
Function: cmd.run
Result: False
Comment: Command "/usr/lib/qubes/upgrades-status-notify" run
Started: 07:46:39.519359
Duration: 5692.826 ms
Changes:
pid:
1835
retcode:
100
stderr:
stdout:
Total states run: 2
Total run time: 22.398 s
Install Whonix 17 templates (gateway+workstation) and use them instead of your old Whonix 16 templates.
You can use Qubes Template Manager GUI tool for this or qvm-template command in dom0 terminal.
Thx, installation worked.
Running the upgrade updating the whonix-gw-16 and whonix-ws-16 failed for the same reason.
Can I go on with all stages and fix this manually the same way after the in place upgrade finished?
Upgrade process stopped after stage 1. ![]()
Just remove Whonix 16 templates so they won’t cause the issues, you won’t need them anymore.
Retry upgrade after removing the templates.
Just remove them, or remove them after I did the manual update for whonix-ws-16 too?
Oh, I overlooked, that you already told me to install both.
