I have trouble installing HP LaserJet M1132 MFP printer and scanner.
I’ve created new qube for that purpose and installed hplip. Then opened HPLIP toolbox and I was able to install the driver. It said that driver was installed.
But when I refresh the list of printers/scanners, it shows me again that main window which says no devices are configured - and this time it doesn’t even see my printer to install.
I’ve enabled network on the template which I use exclusively for HP printer and scanner.
Started hp-setup from terminal (on template)
Attached HP device
Installed it (using ‘root’ as password)
Installed plugin, which was requested by the application
Restarted my laptop
Started HPLIP Toolbox from qube (not template)
Attached HP USB to qube
Refreshed the whole list - nothing was on the list
Started hp-setup from HPLIP Toolbox
Could see “No devices found”
Basically, the steps 10 and 11 seems unnecessary for me but as step 9 didn’t show my my printer, I’ve also tried with those. In other words, it was successfully (or at least it looked so) installed on the template but I cannot use it on the qube. Thanks!
Not sure if it could be this but I’ve never actually installed it. Maybe try doing the process on an appvm and see if it does work. If it does, then it’s an issue with the hplip tool storing files in the template’s user directory which gets overwritten when you open an appvm based on that template.
@Plexus: Probably I also miss something. This is not the password I’ve set, it worked like this by default (just tried with empty pass, it didn’t work, this with pass the same as user and it worked). I guess it’s default password in the templates. Could it be right? Anyway, computer is protected by encryption and anyway the DOM0 doesn’t require any specific password (although I almost never need to do anything there). Is there any way to enforce some password on DOM0 or templates? Or do I miss something important here?
@deeplow: I was able to “install” in on the qube but then there was the same problem - it claimed that it was installed but I couldn’t see the scanner/printer when I refreshed the list of installed devices. I don’t know what is wrong here.
Thank you. I can run sudo hp-setup (but sudo hplip shows nothing). I can install with sudo hp-setup and it seems to work but later there is nothing in HPLIP that I run from the qubes menu. Maybe if I could run sudo hplip-gui from terminal that would help - but hplip or hplip-gui shows ‘command not found’, I can only start ‘hp-setup’ and ‘hp-plugin’ from terminal and HPLIP from the Qubes menu. If, after “successful” installation I run HPLIP from Qubes menu, it doesn’t even see the printer (I’m sure it’s attached to template qube). Similarly on ordinary qube (not template).
sudo apt install hplip-gui shows that it is already installed in the newest version
I am not sure if I get the gist of your question right. I do use a HP
LaserJet like this:
In the template I install hplip and hplip-gui as well as
qubes-usb-proxy obviously
I attach the printer to the template and run sudo hp-setup
Shutdown template and start actual qube you want to print from (it’s
important that that qube was (re-)started AFTER you shutdown the template.
Attach the printer to that qube (not the template anymore!)
Print
Can you try the above steps and tell me where it fails for you?
Thanks. Actually, I have done earlier second step in different way because this way I receive the following:
sudo hp-setup
HP Linux Imaging and Printing System (ver. 3.18.12)
Printer/Fax Setup Utility ver. 9.0
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
Searching... (bus=usb, search=(None), desc=0)
error: Unable to load Qt4 support. Is it installed?
File "usr/share/hplip/ui5/setupdialog.py", line 1296, in NextButton_clicked
self.showDevicesPage()
File "/user/share/hplip/ui5/setupdialog.py", line 561, in showDevicesPage
smart_install.disable(GUI_MODE, 'qt4')
File "/user/share/hplip/base/smart_install.py", line 235, in disable
dialog.exec_()
AttributeError: 'NoneType' object has no attribute 'exec_'
Aborted
So this may be the cause of this problem I have. Please advise.
But hp-setup fails for me (and yes I’m in my template) because “Daemon not running.”
Which daemon? What the heck IS a daemon? and how do I run it?
The only thing I can find is “sudo service cups restart” but doing that changes nothing.
I am able to print test pages, but the printer apparently cannot see my computer for some reason, and I have no idea how to set up to do scans. (I scan far more often than I print.)
Full output to terminal I ran hp-setup in:
HP Linux Imaging and Printing System (ver. 3.21.2)
Copyright (c) 2001-18 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
error: Channel write error
error: Unable To read the XML data from device
Failed to create client object: Daemon not running
Done.
And again…even if I can print (in spite of these error messages), I can’t scan.
i have also faced different problems people have talked about here.
the device i am using is the HP Color Laser Jet Pro MFP M277dw
my preferred connection is usb.
in the template i tried to configure the printer, initially i have only been able to scan. but i screwed up the template with too many experiments… so i started over with a new template and with a little help from gpt5…
finally i ended up only installing…
bash-completion, hplip-gui
then i downloaded the hplip-...-plugin.run & ...-plugin.run.asc and moved it to the template. (needed for scanning i think)*
then in the template i installed the plugin file using sudo hp-plugin using the option to manually specify the plugin file.
also it advised me to enable the cups service in the appvm qube (in services tab in settings dialog)??
following these steps i have got it working in a single print qube now.
also i have configured a disposable/offline/print qube.
i find that not so handy since i am used to be ready to go with the hplip-gui package to connect my old photosmart inkjet printer to any appvm for printing and scanning. i dont remember having to enable the cups service in the settings.
is this suitable for vault environments? i am not exactly sure what implications it has when i am enabling the cups service…
