Installing Freetube, Librewolf and Session in Fedora41 template
I got help installing this stuff on Fedora 40 Template and i went back to the help to copy the help for Fedora-41 Template but nothing seemed to work for me and i was wondering if anyone knows why or how to fix the issue for;
Installing Freetube, Librewolf and Session in Fedora-41 template please?
I have managed to install Brave Browser and Mullvad Browser thus-far but thats about it and the GUI on the Software Manager on the Template doesn’t seem to work either if thats any help?
Maybe i need to install fedora-41xfce instead of fedora-41 i dont know the difference despite trying to research the difference online.
Thanks
Wasn’t here a topic about Librewolf and Session installation anywhere ? Did you try the search ? If I remember correctly it was the very same topic, where they’ve discussed the installation of brave browser…
You may find more success if you clone the template and upgrade it in place. Instructions are in the docs: How to upgrade a Fedora template in-place | Qubes OS
Fedora-41-xfce and Fedora-41 differ in their desktop environment, the latter I believe is still Gnome, while the former is obviously XFCE.
i read those articles but unfortunately they were not about Fedora-41 issue im having and i couldnt get anything useful from them, thanks for trying though. x
That sounds amazing but i am a total beginner and that is for Advanced Users + i dont mind re-doing eveything as i then get a chance to learn how to do it and remain fresh i was thinking but im not sure why the advise i got for fedora-40 is not working for fedora-41 its baffle me for sure, i tried to do the flatpac thingy but that no work either yet it did work for fedore-40 so me still confuse on that one too?
However when i open up Terminal on fedora-41 Template it seems i have flatpak already installed yet i dont seem to be able to install flathub apps such as session messenger or such like?
[user@fedora-41 ~]$ sudo dnf install flatpak
Updating and loading repositories:
Repositories loaded.
Package “flatpak-1.15.10-1.fc41.x86_64” is already installed.
Nothing to do.
[user@fedora-41 ~]$ flatpak install flathub network.loki.Session
Looking for matches…
error: Unable to load summary from remote flathub: While fetching https://dl.flathub.org/repo/summary.idx: [6] Could not resolve hostname
[user@fedora-41 ~]$
