Installing emacs packages on template qube
How would you go about installing an emacs package on a template machine? These are my thoughts:
(1) The worst option is to grant the template machine temporary internet access and install the packages.
(2) so, you can git clone the packages (say over a whonix session, and then move the files to the template machine). Then do a local install of the cloned packages. This approach may lead to a lot of work.
(3) use the proxy server - much like for python packages (pip install --proxy=http:127.0.0.1:8082 packagename). However, I do not know how to do this.
This is my user-case:
I have a template debian qube used by two (or three) VMs. These VMs are for code development, code testing etc. The VMs have no internet access (so that, for example, there is no sneaky way for VS code to send telemetry anywhere…). It would be great to never grant these machines internet access - and to configure emacs on the template machine once and for all, so that I basically have the same configuration on all dev machines.
For python packages, I already do something on these lines: create some base environments on the template that can be activated on the VMs.
I don’t use emacs, but in general, what emacs packages you already can’t find in template available repositories?
Or, better, what are you trying to achieve?
@enmus, thank you for considering the question. As far as I understood, none of emacs packages are listed in template available repositories. But it would be fantastic if I am wrong here. The repos I know for emacs are:
In the end, there is a way to tell emacs to use the qubes proxy (like in pip). Following:
The code below worked on my emacs when placed on the init.el config file:
(setq url-proxy-services’(
; (“no_proxy” . “^\(localhost\|10.*\)”)
(“http” . “127.0.0.1:8082”)
(“https” . “127.0.0.1:8082”)
(require 'package)
; NOTE: can include here local folder – see elpy instructions for manual download
(setq package-archives '(
; (“melpa” . “Package Listing”)
(“org” . “Index of /elpa/”)
; (“elpa” . “GNU ELPA Packages”)
Sorry if I’m wasting your time, but what you get when you type sudo dnf search elpa and sudo apt search elpa in your fedora and debian templates’ terminals? Not packages you’d want?
@buvivv Thanks for the post, got it working for me.
@enmus Basically, emacs has its own package repositories. sudo dnf search elpa won’t work since that command is for linux packages.
So, noting of these doesn’t satisfy your needs:
Sorry if this is noise
user@debian-11-minimal:~$ sudo apt search elpa
Sorting… Done
Full Text Search… Done
auto-complete-el/stable 1.5.1-0.2 all
transitional package for elpa-auto-complete
autodep8/stable 0.24 all
DEP-8 test control file generator
c-sig/stable 3.8-24 all
Transition package, c-sig to elpa-c-sig
darcsum/stable 1.10+20120116-4 all
Transition package, darcsum to elpa-darcsum
dash-el/stable 2.17.0+dfsg-1 all
transitional dummy package for elpa-dash
debian-el/stable 37.10 all
Transition package, debian-el to elpa-debian-el
devscripts-el/stable 40.5 all
Transition package, devscripts-el to elpa-devscripts
dh-elpa/stable 2.0.8 all
Debian helper tools for packaging emacs lisp extensions
dh-elpa-helper/stable 2.0.8 all
helper package for emacs lisp extensions
dh-make-elpa/stable 0.19.1 all
helper for creating Debian packages from ELPA packages
dictionary-el/stable 1.10+git20190107-3 all
transitional dummy package, dictionary-el to elpa-dictionary
dpkg-dev-el/stable 37.9 all
Transition package, dpkg-dev-el to elpa-dpkg-dev-el
elpa-ac-rtags/stable 2.38-3 all
auto-complete back-end for RTags
elpa-ace-link/stable 0.5.0-3 all
selecting a link to jump to
elpa-ace-popup-menu/stable 0.2.1-3 all
replace GUI popup menu with something more efficient
elpa-ace-window/stable 0.10.0-1 all
selecting a window to switch to
elpa-adaptive-wrap/stable 0.8-1 all
smart line-wrapping with wrap-prefix
elpa-ag/stable 0.48-1 all
Emacs frontend to ag
elpa-agda2-mode/stable 2.6.1-1 all
dependently typed functional programming language ?? emacs mode
elpa-aggressive-indent/stable 1.9.0-3 all
Emacs minor mode that reindents code after every change
elpa-anzu/stable 0.64-1 all
show number of matches in mode-line while searching
elpa-apache-mode/stable 2.2.0-3 all
Emacs major mode for editing Apache configuration files
elpa-apiwrap/stable 0.5-4 all
api-wrapping macros
elpa-assess/stable 0.6-1 all
test support functions for Emacs
elpa-async/stable 1.9.4-2 all
simple library for asynchronous processing in Emacs
elpa-atomic-chrome/stable 2.0.0-2 all
edit a web-browser text entry area with Emacs
elpa-ats2-mode/stable 0.4.0-1 all
ATS version 2 programming language emacs mode
elpa-auto-complete/stable 1.5.1-0.2 all
intelligent auto-completion extension for GNU Emacs
elpa-auto-dictionary/stable 1.1+14.gb364e08-1 all
automatic dictionary switcher for Emacs spell checking
elpa-avy/stable 0.5.0-2 all
jump to things in Emacs tree-style
elpa-avy-menu/stable 0.1.1-3 all
library providing avy-powered popup menu
elpa-bar-cursor/stable 2.0-1.1 all
switch Emacs block cursor to a bar
elpa-beacon/stable 1.3.3-3 all
highlight the cursor whenever the window scrolls
elpa-beginend/stable 2.2.0-1 all
redefine M-< and M-> for some modes to get to meaningful locations
elpa-bind-chord/stable 2.4.1-1 all
key-chord binding helper for use-package-chords
elpa-bind-key/stable 2.4.1-1 all
simple way to manage personal keybindings
elpa-bind-map/stable 1.1.1-5 all
bind personal keymaps in multiple locations
elpa-bm/stable 201905-2 all
visual bookmarks for GNU Emacs
elpa-bongo/stable 1.1-2 all
buffer-oriented media player for GNU Emacs
elpa-boxquote/stable 2.2-1 all
quote text in Emacs with a semi-box
elpa-browse-kill-ring/stable 2.0.0-3 all
interactively insert items from kill-ring
elpa-bug-hunter/stable 1.3.1+repack-5 all
automatically debug and bisect your init.el or .emacs file
elpa-buttercup/stable 1.24-1 all
behaviour-driven testing for Emacs Lisp packages
elpa-c-sig/stable 3.8-24 all
signature tool for GNU Emacs
elpa-caml/stable 4.06-2 all
emacs mode for editing OCaml programs
elpa-char-menu/stable 0.1.1-3 all
create your own menu for fast insertion of arbitrary symbols
elpa-cider/stable 0.19.0+dfsg-2.1 all
Clojure IDE for Emacs
elpa-circe/stable 2.11-2 all
client for IRC in Emacs
elpa-clojure-mode/stable 5.10.0-3 all
Emacs major mode for Clojure code
elpa-clojure-mode-extra-font-locking/stable 5.10.0-3 all
extra font-locking for clojure-mode
elpa-closql/stable 1.0.4-2 all
Store EIEIO objects using EmacSQL
elpa-clues-theme/stable 1.0.1-2.1 all
cream/brown/orange color theme for Emacs
elpa-color-theme-modern/stable 0.0.3-1 all
deftheme reimplementation of classic Emacs color-themes
elpa-company/stable 0.9.13-2 all
Modular in-buffer completion framework for Emacs
elpa-company-lsp/stable 2.1.0-3 all
Company completion backend for emacs lsp-mode.
elpa-company-rtags/stable 2.38-3 all
company back-end for RTags
elpa-concurrent/stable 0.5.1-4 all
higher level library for concurrent tasks
elpa-counsel/stable 0.13.0-1 all
collection of Ivy-enhanced versions of common Emacs commands
elpa-csv-mode/stable 1.12-1 all
Emacs major mode for editing comma, char, and tab separated values
elpa-ctable/stable 0.1.2-6 all
table component for Emacs Lisp
elpa-cycle-quotes/stable 0.1-4 all
Emacs command to cycle between quotation marks
elpa-darcsum/stable 1.10+20120116-4 all
pcl-cvs like interface for managing darcs patches
elpa-dash/stable 2.17.0+dfsg-1 all
modern list manipulation library for Emacs
elpa-dash-functional/stable 1.2.0+dfsg-7 all
collection of functional combinators for Emacs Lisp
elpa-db/stable 0.0.6+git20140421.b3a423f-3 all
database interface for Emacs Lisp
elpa-debian-el/stable 37.10 all
Emacs helpers specific to Debian users
elpa-debpaste/stable 0.1.5-4 all
paste.debian.net client for Emacs
elpa-deferred/stable 0.5.1-4 all
simple asynchronous functions for Emacs Lisp
elpa-deft/stable 0.8-3 all
Emacs mode to browse, filter, and edit plain text notes
elpa-devscripts/stable 40.5 all
Emacs wrappers for the commands in devscripts
elpa-dictionary/stable 1.10+git20190107-3 all
dictionary client for Emacs
elpa-diff-hl/stable 1.8.8-1 all
highlight uncommitted changes using VC
elpa-diffview/stable 1.0-3 all
view diffs in side-by-side format
elpa-diminish/stable 0.45-4 all
hiding or abbreviation of the mode line displays of minor-modes
elpa-dimmer/stable 0.4.2+repack-2 all
visually highlight the selected buffer
elpa-dired-du/stable 0.5.2-2 all
dired with recursive directory sizes
elpa-dired-quick-sort/stable 0.1.1-1 all
persistent quick sorting of dired buffers in various ways
elpa-dired-rsync/stable 0.6-1 all
support for rsync from Emacs dired buffers
elpa-discover-my-major/stable 1.0-4 all
discover key bindings and their meaning for the current Emacs major mode
elpa-dockerfile-mode/stable 1.2-2 all
Major mode for editing Docker’s Dockerfiles
elpa-dpkg-dev-el/stable 37.9 all
Emacs helpers specific to Debian development
elpa-dumb-jump/stable 0.5.3-1 all
jump to definition for multiple languages without configuration
elpa-ebib/stable 2.15.4-3 all
BibTeX database manager for Emacs
elpa-ediprolog/stable 2.1-1 all
Emacs Does Interactive Prolog
elpa-editorconfig/stable 0.8.1-3 all
coding style indenter for all editors - Emacsen plugin
elpa-el-mock/stable 1.25.1-4 all
tiny mock and stub framework for Emacs Lisp
elpa-el-x/stable 0.3.1-4 all
Emacs Lisp extensions
elpa-elfeed/stable 3.4.1-1 all
Emacs Atom/RSS feed reader
elpa-elfeed-web/stable 3.4.1-1 all
Emacs Atom/RSS feed reader - web interface
elpa-elisp-refs/stable 1.3-3 all
find callers of elisp functions or macros
elpa-elisp-slime-nav/stable 0.9-5 all
Emacs extension that provide Emacs Lisp code navigation
elpa-elm-mode/stable 0.20.3-3 all
Major Emacs mode for editing Elm source code
elpa-elpher/stable 2.10.2-2 all
friendly gopher and gemini client
elpa-emacsql/stable 3.0.0+ds-2 all
high level SQL database frontend for Emacs
elpa-emacsql-mysql/stable 3.0.0+ds-2 all
elpa-emacsql-psql/stable 3.0.0+ds-2 all
elpa-emacsql-sqlite/stable 3.0.0+ds-2 amd64
elpa-emacsql-sqlite3/stable 1.0.2-1 all
Yet another EmacSQL backend for SQLite
elpa-engine-mode/stable 2.1.1-1 all
define and query search engines from within Emacs
elpa-epc/stable 0.1.1-6 all
RPC stack for Emacs Lisp
elpa-epl/stable 0.9-3 all
Emacs Package Library
elpa-eproject/stable 1.5+git20180312.068218d-3 all
assign files to Emacs projects, programmatically
elpa-ert-async/stable 0.1.2-5 all
asynchronous tests for the Emacs ERT testing framework
elpa-ert-expectations/stable 0.2-4 all
very simple unit test framework for Emacs Lisp
elpa-esh-help/stable 1.0.1-2.1 all
add some help functions and support for Eshell
elpa-eshell-bookmark/stable 2.0.0-2.1 all
integrate bookmarks with Eshell
elpa-eshell-git-prompt/stable 0.1.2-4 all
Eshell prompt themes for Git users
elpa-eshell-prompt-extras/stable 1.0-1 all
display extra information in your Eshell prompt
elpa-eshell-up/stable 0.0.3-5 all
quickly go to a specific parent directory in eshell
elpa-eshell-z/stable 0.4-3 all
cd to frequent directory in eshell
elpa-ess/stable 18.10.2-2 all
Emacs mode for statistical programming and data analysis
elpa-esup/stable 0.7.1-3 all
Emacs StartUp Profiler
elpa-esxml/stable 0.3.5-1 all
XML, ESXML and SXML library for Emacs Lisp
elpa-evil/stable 1.14.0-1 all
extensible vi layer for Emacs
elpa-evil-paredit/stable 0.0.2-5 all
emacs extension, integrating evil and paredit
elpa-exec-path-from-shell/stable 1.12-2 all
get environment variables such as $PATH from the shell
elpa-expand-region/stable 0.11.0+36-1 all
Increase selected region in Emacs by semantic units
elpa-eyebrowse/stable 0.7.8-2 all
simple-minded way of managing window configs in Emacs
elpa-f/stable 0.20.0-3 all
modern API for working with files and directories in Emacs Lisp
elpa-faceup/stable 0.0.4-5 all
Regression test system for font-lock
elpa-fill-column-indicator/stable 1.90-2.1 all
graphically indicate the fill column
elpa-find-file-in-project/stable 6.0.1-1 all
quick access to project files in Emacs
elpa-flx/stable 0.6.1-5 all
sorting algorithm for fuzzy matching in Emacs
elpa-flx-ido/stable 0.6.1-5 all
allows Emacs Ido to use the flx sorting algorithm
elpa-flycheck/stable 32~git.20200527.9c435db3-2 all
modern on-the-fly syntax checking for Emacs
elpa-flycheck-package/stable 0.13-1 all
flycheck checker for Elisp package authors
elpa-flycheck-rtags/stable 2.38-3 all
flycheck integration for RTags
elpa-folding/stable 0+20200825.748-1 all
folding-editor minor mode for Emacs
elpa-fountain-mode/stable 2.8.5-1 all
Emacs major mode for screenwriting in Fountain markup
elpa-fricas/stable 1.3.6-6 all
General purpose computer algebra system: emacs support
elpa-fsm/stable 0.2.1-4 all
state machine library
elpa-geiser/stable 0.10-1 all
enhanced Scheme interaction mode for Emacs
elpa-ggtags/stable 0.8.13-2 all
improved Emacs interface to GNU GLOBAL
elpa-ghub/stable 3.5.1-1 all
minuscule client for the Github API
elpa-ghub+/stable 0.3-6 all
thick GitHub API client built on ghub
elpa-git-annex/stable 1.1-4 all
Emacs integration for git-annex
elpa-git-auto-commit-mode/stable 4.7.0-2 all
Emacs Minor mode to automatically commit and push with git
elpa-git-commit/stable 2.99.0.git0957.ge8c7bd03-1 all
Major mode for editing git commit message
elpa-git-messenger/stable 0.18-5 all
pop up last commit information of current line
elpa-git-modes/stable 1.2.8-4 all
major modes for editing Git configuration files
elpa-git-timemachine/stable 4.11-1 all
walk through git revisions of a file
elpa-gitattributes-mode/stable 1.2.8-4 all
major mode for editing Git configuration files (gitattributes)
elpa-gitconfig-mode/stable 1.2.8-4 all
major mode for editing Git configuration files (gitconfig and gitmodules)
elpa-gitignore-mode/stable 1.2.8-4 all
major mode for editing Git configuration files (gitignore)
elpa-gitlab-ci-mode/stable 20190824.12.2-2 all
Emacs mode for editing GitLab CI files
elpa-gnuplot-mode/stable 1:0.7.0-2014-12-31-2 all
Gnuplot mode for Emacs
elpa-go-mode/stable 3:1.5.0-4 all
Emacs mode for editing Go code
elpa-golden-ratio/stable 1.0-6 all
automatic resizing of Emacs windows to the golden ratio
elpa-goo/stable 0.155+ds-4 all
generic object-orientator (Emacs support)
elpa-goto-chg/stable 1.7.3-1 all
navigate the point to the most recent edit in the buffer
elpa-graphql/stable 0.1.1-5 all
GraphQL utilities
elpa-graphviz-dot-mode/stable 0.4.2-2 all
Emacs mode for the dot-language used by graphviz.
elpa-haskell-mode/stable 17.2-3 all
major mode for editing Haskell in Emacs
elpa-haskell-tab-indent/stable 0.3-3 all
tab-based indentation for haskell-mode
elpa-helm/stable 3.7.0-2 all
Emacs incremental completion and selection narrowing framework
elpa-helm-ag/stable 0.59-1 all
Silver Searcher integration with Emacs Helm
elpa-helm-core/stable 3.7.0-2 all
Emacs Helm library files
elpa-helm-org/stable 1.0-2 all
Emacs Helm for Org-mode headlines and keywords completion
elpa-helm-projectile/stable 0.14.0-6 all
Helm integration for Projectile
elpa-helm-rtags/stable 2.38-3 all
helm interface for RTags
elpa-helm-virtualenvwrapper/stable 0.2.0-2 all
helm-source for virtualenvwrapper.el
elpa-helpful/stable 0.18-1 all
better help buffer
elpa-highlight-indentation/stable 0.7.0-5 all
highlight the indentation level in Emacs buffers
elpa-highlight-numbers/stable 0.2.3-6 all
highlight numbers in source code
elpa-hl-todo/stable 3.1.2-1 all
highlight TODO and similar keywords in comments and strings
elpa-ht/stable 2.3-1 all
hash table library for Emacs
elpa-htmlize/stable 1.55-1 all
convert buffer text and decorations to HTML
elpa-hungry-delete/stable 1.1.5-7 all
enable hungry deletion in all modes
elpa-hydra/stable 0.15.0-3 all
make Emacs bindings that stick around
elpa-ibuffer-projectile/stable 0.3-1 all
group buffers in ibuffer list by Projectile project
elpa-ibuffer-vc/stable 0.11-1 all
group ibuffer list by VC project and show VC status
elpa-ido-completing-read+/stable 4.13-2 all
completing-read-function using ido
elpa-ido-vertical-mode/stable 0.1.6-5 all
make ido-mode display vertically
elpa-iedit/stable 0.9.9.9-5 all
edit multiple regions in the same way simultaneously
elpa-imenu-list/stable 0.8-3 all
show the current Emacs buffer’s imenu entries in a separate window
elpa-initsplit/stable 1.8+3+gc941d43-3 all
code to split customizations into different files
elpa-irony/stable 1.4.0+7.g76fd37f-1 all
Emacs C/C++ minor mode powered by libclang
elpa-ivy/stable 0.13.0-1 all
generic completion mechanism for Emacs
elpa-ivy-hydra/stable 0.13.0-1 all
additional key bindings for Emacs Ivy
elpa-ivy-rtags/stable 2.38-3 all
ivy back-end for RTags
elpa-jabber/stable 0.8.92+git98dc8e-6 all
Jabber client for Emacsen
elpa-jedi/stable 0.2.8-1 all
Python auto-completion for Emacs
elpa-jedi-core/stable 0.2.8-1 all
common code of jedi.el and company-jedi.el
elpa-jinja2-mode/stable 0.2+git20200624.159558e-1 all
Emacs major mode for editing jinja2 code
elpa-js2-mode/stable 0~20201220-1 all
Emacs mode for editing Javascript programs
elpa-key-chord/stable 0.6-5 all
map pairs of simultaneously pressed keys to commands
elpa-kv/stable 0.0.19+git20140108.7211484-4 all
key/value data structure functions for Emacs Lisp
elpa-lbdb/stable 0.49 all
Little Brother’s DataBase Emacs extensions
elpa-ledger/stable 3.1.2~pre3+g5067e408-2 all
command-line double-entry accounting program (emacs interface)
elpa-let-alist/stable 1.0.6-2 all
let-bind values of an assoc-list by their names in Emacs Lisp
elpa-linum-relative/stable 0.6-2.1 all
display relative line number in Emacs
elpa-load-relative/stable 1.3.1-3 all
relative file load (within a multi-file Emacs package)
elpa-loop/stable 1.3-2.1 all
friendly imperative loop structures for Emacs Lisp
elpa-lsp-haskell/stable 1.0.20201011-1 all
Haskell support for lsp-mode
elpa-lsp-mode/stable 7.0.1-2 all
Emacs client/library for the Language Server Protocol
elpa-lsp-ui/stable 7.0.1-1 all
UI modules for lsp-mode
elpa-lua-mode/stable 20201010-1 all
Emacs major-mode for editing Lua programs
elpa-lv/stable 0.15.0-3 all
other echo area
elpa-m-buffer/stable 0.15-2.1 all
list-oriented, functional buffer manipulation
elpa-macaulay2/stable 1.17.1+ds-2 all
Software system for algebraic geometry research (Emacs package)
elpa-magit/stable 2.99.0.git0957.ge8c7bd03-1 all
Emacs interface for Git
elpa-magit-annex/stable 1.7.1+git20200427.01.ef5dce62-1 all
git-annex subcommands for magit
elpa-magit-forge/stable 0.1.0+git20200714.639ce51-3 all
Work with Git forges from the comfort of Magit
elpa-magit-popup/stable 2.13.2-1 all
Use popup like Magit
elpa-magit-todos/stable 1.5.3-1 all
show source file TODOs in Magit
elpa-mailscripts/stable 0.23-1 all
Emacs functions for accessing tools in the mailscripts package
elpa-makey/stable 0.3-4 all
flexible context menu system
elpa-markdown-mode/stable 2.4-1 all
mode for editing Markdown-formatted text files in GNU Emacs
elpa-markdown-toc/stable 0.1.5-1 all
Emacs TOC (table of contents) generator for markdown files
elpa-memoize/stable 1.1-2.1 all
memoization functions
elpa-meson-mode/stable 0.3-1 all
Major mode for the Meson build system files
elpa-message-templ/stable 0.3.20161104-3 all
templates for Emacs message-mode
elpa-migemo/stable 1.9.2-3 all
Japanese incremental search with Romaji on Emacsen
elpa-minimap/stable 1.4-1 all
sidebar showing a “mini-map” of a buffer
elpa-mocker/stable 0.5.0-1 all
mocking framework for Emacs
elpa-modus-themes/stable 1.0.2-1 all
set of accessible themes conforming with WCAG AAA accessibility standard
elpa-monokai-theme/stable 3.5.3-3 all
fruity color theme for Emacs
elpa-move-text/stable 2.0.8-2.1 all
move current line or region up and down
elpa-muse/stable 3.20+dfsg-6 all
author and publish projects using Wiki-like markup
elpa-mutt-alias/stable 1.5-4 all
Emacs package to lookup and insert expanded Mutt mail aliases
elpa-muttrc-mode/stable 1.2.1-3 all
Emacs major mode for editing muttrc
elpa-neotree/stable 0.5.2-3 all
directory tree sidebar for Emacs that is like NERDTree for Vim
elpa-no-littering/stable 1.2.1-1 all
help keeping ~/.emacs.d clean
elpa-noflet/stable 0.0.15-5 all
Emacs Lisp noflet macro for dynamic, local advice
elpa-nose/stable 0.1.1-5 all
easy Python test running in Emacs
elpa-notmuch/stable 0.31.4-2 all
thread-based email index, search and tagging (emacs interface)
elpa-nov/stable 0.3.0-1 all
featureful EPUB (ebook) reader mode for Emacs
elpa-olivetti/stable 1.11.3-1 all
Emacs minor mode to more comfortably read and write long-lined prose
elpa-openwith/stable 0.8g-5 all
seamlessly open files in external programs with Emacs
elpa-org/stable 9.4.0+dfsg-1 all
Keep notes, maintain ToDo lists, and do project planning in emacs
elpa-org-bullets/stable 0.2.4-3.1 all
show bullets in Org-mode as UTF-8 characters
elpa-org-drill/stable 2.7.0+20200412+dfsg1-2 all
emacs org-mode contrib for self-testing using spaced repetition
elpa-org-roam/stable 1.2.3-2 all
non-hierarchical note-taking with Emacs Org-mode
elpa-orgalist/stable 1.12-2 all
Manage Org-like lists in non-Org Emacs buffers
elpa-ox-texinfo+/stable 2.2.4-2 all
Extensions for Org’s Texinfo exporter
elpa-package-lint/stable 0.13-1 all
linting library for Elisp package authors
elpa-package-lint-flymake/stable 0.13-1 all
package-lint Flymake backend
elpa-paredit/stable 24-5 all
Emacs minor mode for structurally editing Lisp code
elpa-paredit-everywhere/stable 0.4-4 all
cut-down version of paredit for non-lisp buffers
elpa-parent-mode/stable 2.3-5 all
get major mode’s parent modes
elpa-parsebib/stable 2.3.1-4 all
Emacs Lisp library for parsing .bib files
elpa-pcre2el/stable 1.8-4 all
Emacs mode to convert between PCRE, Emacs and rx regexp syntax
elpa-pdf-tools/stable 1.0~20200512-2 all
Display and interact with pdf in Emacs
elpa-pdf-tools-server/stable 1.0~20200512-2 amd64
server for Emacs’s pdf-tools
elpa-persist/stable 0.4+dfsg-2 all
persist variables between Emacs Sessions
elpa-perspective/stable 2.2-3 all
tagged workspaces in Emacs
elpa-pg/stable 0.13+git.20130731.456516ec-2 all
Emacs Lisp interface for PostgreSQL
elpa-php-mode/stable 1.23.0-1 all
PHP Mode for GNU Emacs
elpa-pip-requirements/stable 0.5-3 all
major mode for editing pip requirements files
elpa-pkg-info/stable 0.6-6 all
provide information about Emacs packages
elpa-pod-mode/stable 1.03-3 all
Emacs major mode for editing .pod files
elpa-pointback/stable 0.2-4 all
restore window points when returning to buffers
elpa-popup/stable 0.5.8-1 all
visual popup user interface library for Emacs
elpa-pos-tip/stable 0.4.6+git20191227-2 all
Show tooltip at point
elpa-powerline/stable 2.4-4 all
Emacs version of the Vim powerline
elpa-project/stable 0.5.2-2 all
Emacs library for operations on the current project
elpa-projectile/stable 2.1.0-1 all
project interaction library for Emacs
elpa-protobuf-mode/stable 3.12.4-1 all
Emacs addon for editing protocol buffers
elpa-ps-ccrypt/stable 1.11-2 all
Emacs addon for working with files encrypted with ccrypt
elpa-puppet-mode/stable 0.4-2 all
Emacs major mode for Puppet manifests
elpa-py-autopep8/stable 2016.1-3 all
use autopep8 to beautify a Python buffer
elpa-py-isort/stable 2016.1-5 all
use isort to sort the imports in a Python buffer
elpa-python-environment/stable 0.0.2-6 all
virtualenv API for Emacs Lisp
elpa-pyvenv/stable 1.21+git20201124.37e7cb1-1 all
Python virtual environment interface
elpa-qml-mode/stable 0.4-4 all
Emacs major mode for editing QT Declarative (QML) code
elpa-queue/stable 0.2-3 all
queue data structure for Emacs Lisp
elpa-racket-mode/stable 20201227git0-3 all
emacs support for editing and running racket code
elpa-rainbow-delimiters/stable 2.1.3-5 all
Emacs mode to colour-code delimiters according to their depth
elpa-rainbow-identifiers/stable 0.2.2-5 all
highlight identifiers according to their names
elpa-rainbow-mode/stable 1.0.5-1 all
colorize color names in buffers
elpa-recursive-narrow/stable 20140811.1546+git20190306.5e3e206-1 all
narrow-to-region that operates recursively
elpa-redtick/stable 00.01.02+git20170220.e6d2e9b+dfsg-4 all
tiny pomodoro timer for Emacs
elpa-relint/stable 1.19-1 all
Emacs Lisp regexp mistake finder
elpa-restart-emacs/stable 0.1.1-4 all
restart emacs from within emacs
elpa-rich-minority/stable 1.0.3-2 all
clean-up and beautify the list of minor-modes in Emacs’ mode-line
elpa-rtags/stable 2.38-3 all
emacs front-end for RTags
elpa-rust-mode/stable 0.4.0-2 all
Major Emacs mode for editing Rust source code
elpa-s/stable 1.12.0-4 all
string manipulation library for Emacs
elpa-scala-mode/stable 1:1.1.0-2 all
Emacs major mode for editing scala source code
elpa-seq/stable 2.22-1 all
sequence manipulation functions for Emacs Lisp
elpa-sesman/stable 0.3.4-2 all
session manager for Emacs IDEs
elpa-session/stable 2.4b-3 all
use variables, registers and buffer places across sessions
elpa-shut-up/stable 0.3.3-1 all
Emacs Lisp macros to quieten Emacs
elpa-simple-httpd/stable 1.5.1-4 all
pure elisp HTTP server
elpa-smart-mode-line/stable 2.13-2 all
powerful and beautiful mode-line for Emacs
elpa-smart-mode-line-powerline-theme/stable 2.13-2 all
Smart Mode Line themes that use Emacs Powerline
elpa-smeargle/stable 0.03-5 all
highlight region by last updated time
elpa-smex/stable 3.0-6 all
M-x interface for Emacs with Ido-style fuzzy matching
elpa-sml-mode/stable 6.10-1 all
Emacs major mode for editing Standard ML programs
elpa-solarized-theme/stable 1.3.1-1 all
port of Solarized theme to Emacs
elpa-spinner/stable 1.7.3-3 all
spinner for the Emacs modeline for operations in progress
elpa-suggest/stable 0.7-3 all
discover Emacs Lisp functions based on examples
elpa-super-save/stable 0.3.0-3 all
auto-save buffers, based on your activity
elpa-swiper/stable 0.13.0-1 all
alternative to Emacs’ isearch, with an overview
elpa-sxiv/stable 0.3.3-1 all
run the sxiv image viewer
elpa-system-packages/stable 1.0.11-2 all
functions to manage system packages
elpa-systemd/stable 1.6-2.1 all
major mode for editing systemd units
elpa-tabbar/stable 2.2-4 all
Emacs minor mode that displays a tab bar at the top
elpa-tablist/stable 1.0-2 all
tablist adds maks and filters to tabulated-list-mode
elpa-transient/stable 0.2.0.30.g4d44d08-2 all
Emacs key and popup interface for complex keybindings
elpa-transient-doc/stable 0.2.0.30.g4d44d08-2 all
elpa-transmission/stable 0.12.2-1 all
Emacs interface to a Transmission session
elpa-treepy/stable 0.1.2-1 all
Generic tree traversal tools
elpa-tuareg/stable 1:2.2.0-1 all
emacs-mode for OCaml programs
elpa-undercover/stable 0.8.0-1 all
test coverage library for Emacs Lisp
elpa-undo-tree/stable 0.7.4-1 all
Emacs minor mode for handling undo history as tree
elpa-use-package/stable 2.4.1-1 all
configuration macro for simplifying your .emacs
elpa-use-package-chords/stable 2.4.1-1 all
key-chord keyword for use-package
elpa-use-package-ensure-system-package/stable 2.4.1-1 all
autoinstall system packages
elpa-uuid/stable 0.0.3~git20120910.1519bfe-3 all
UUID/GUID library for Emacs Lisp
elpa-vala-mode/stable 0.1-8 all
Emacs editor major mode for vala source code
elpa-vc-fossil/stable 2020.09.20-4 all
Emacs VC backend for the Fossil Version Control system
elpa-verbiste/stable 0.1.47-1 all
French and Italian conjugator - emacs extension
elpa-vimish-fold/stable 0.2.3-5 all
fold text in GNU Emacs like in Vim
elpa-virtualenvwrapper/stable 0.2.0-2 all
featureful virtualenv tool for Emacs
elpa-visual-fill-column/stable 2.3-1 all
Emacs mode that wraps visual-line-mode buffers at fill-column
elpa-visual-regexp/stable 1.1.2-2 all
in-buffer visual feedback while using Emacs regexps
elpa-volume/stable 1.0+git.20201002.afb75a5-3 all
tweak your sound card volume from Emacs
elpa-wc-mode/stable 1.4-1 all
display a word count in the Emacs modeline
elpa-web-mode/stable 17.0.2-1 all
major emacs mode for editing web templates
elpa-websocket/stable 1.13-1 all
Emacs WebSocket client and server
elpa-weechat/stable 0.5.0-5 all
Chat via WeeChat’s relay protocol in Emacs.
elpa-wgrep/stable 2.3.2+9.gf0ef9bf-2 all
edit multiple Emacs buffers using a master grep pattern buffer
elpa-wgrep-ack/stable 2.3.2+9.gf0ef9bf-2 all
edit multiple Emacs buffers using a master ack pattern buffer
elpa-wgrep-ag/stable 2.3.2+9.gf0ef9bf-2 all
edit multiple Emacs buffers using a master ag pattern buffer
elpa-wgrep-helm/stable 2.3.2+9.gf0ef9bf-2 all
edit multiple Emacs buffers with a helm-grep-mode buffer
elpa-which-key/stable 3.5.1-1 all
display available keybindings in popup
elpa-with-editor/stable 3.0.2-1 all
call program using Emacs as $EDITOR
elpa-with-simulated-input/stable 2.4+git20200216.29173588-1 all
macro to simulate user input non-interactively
elpa-world-time-mode/stable 0.0.6-4 all
Emacs mode to compare timezones throughout the day
elpa-writegood-mode/stable 2.0.3-3 all
Emacs minor mode that provides hints for common English writing problems
elpa-ws-butler/stable 0.6-4 all
unobtrusively remove trailing whitespace in Emacs
elpa-xcite/stable 1.60-7 all
exciting cite utility for Emacsen
elpa-xcscope/stable 1.5-1.1 all
Interactively examine a C program source in emacs
elpa-xml-rpc/stable 1.6.12-4 all
Emacs Lisp XML-RPC client
elpa-xr/stable 1.21-1 all
convert string regexp to rx notation
elpa-xref/stable 1.0.2-2 all
Library for cross-referencing commands in Emacs
elpa-yaml-mode/stable 0.0.15-1 all
Emacs major mode for YAML files
elpa-yasnippet/stable 0.14.0+git20200603.5cbdbf0d-1 all
template system for Emacs
elpa-yasnippet-snippets/stable 0.23-1 all
Andrea Crotti’s official YASnippet snippets
elpa-zenburn-theme/stable 2.6-3 all
low contrast color theme for Emacs
elpa-ztree/stable 1.0.5-4 all
text mode directory tree
elpa-zzz-to-char/stable 0.1.3-3 all
fancy version of `zap-to-char’ command
emacs-goodies-el/stable 42.3 all
Miscellaneous add-ons for Emacs
emacs-jabber/stable 0.8.92+git98dc8e-6 all
Transition package, emacs-jabber to elpa-jabber
Transition Package, ess to elpa-ess
expand-region-el/stable 0.11.0+36-1 all
Transition package, expand-region-el to elpa-expand-region
fortran-language-server/stable 1.12.0-1 all
Fortran Language Server for the Language Server Protocol
Transition Package, geiser to elpa-geiser
Transition Package, gnuplot-mode to elpa-gnuplot-mode
golang-mode/stable 3:1.5.0-4 all
Emacs mode for editing Go code – transitional package
libelpa-dev/stable 2019.11.001-4 amd64
Eigenvalue SoLvers for Petaflop-Applications (Development version)
libelpa15/stable 2019.11.001-4 amd64
migemo-el/stable 1:1.2+gh0.20150404-7.1 all
transitional dummy package: elpa-migemo
ocaml-mode/stable 4.06-2 all
transitional package to elpa-caml
org-mode/stable 9.4.0+dfsg-1 all
Transition Package, org-mode to elpa-org
s-el/stable 1.12.0-4 all
transitional dummy package, s-el to elpa-s
scala-mode-el/stable 1:1.1.0-2 all
transitional dummy package, scala-mode-el to elpa-scala-mode
silversearcher-ag-el/stable 0.48-1 all
transitional dummy package, silversearcher-ag-el to elpa-ag
Transition package, sml-mode to elpa-sml-mode
tuareg-mode/stable 1:2.2.0-1 all
transitional package, tuareg-mode to elpa-tuareg
vala-mode-el/stable 0.1-8 all
Transition Package, vala-mode-el to elpa-vala-mode
verbiste-el/stable 0.1.47-1 all
transitional package, verbiste-el to elpa-verbiste
Transition Package, xcite to elpa-xcite
xcscope-el/stable 1.5-1.1 all
Transition Package, xcscope-el to elpa-xcscope
transition Package, yasnippet to elpa-yasnippet
youtube-dl/stable 2021.06.06-1 all
downloader of videos from YouTube and other sites
yt-dlp/bullseye-backports 2022.11.11-1~bpo11+1 all
Quite interesting indeed!
But I don’t think that’s the standard way of installing packages in emacs. At least, I’ve never seen it done through the apt package manager.
The approach I’ve taken is to create a dummy internet-accessible qube with nothing in home except a barebones ~/.emacs.d/custom.el, ~/.emacs.d/init.el, enough just to install packages with M-x package-install, and then once you’ve installed your elisp packages, qvm-copy the following dirs from the dummy qube into the offline “real” Emacs/development qubes:
~/.emacs.d/elpa
~/.emacs.d/eln-cache
If you install or update elisp packages frequently you could get cleverer with the sync. From dom0, tar the dirs from dummy qube into dev qubes with piped qvm-runs.
It would be cleaner just to assemble everything in the template but I feel this is a pragmatic compromise.
