"Installing blackarch" has outdated instructions
Here are some things I had to do in order to install blackarch in a template.
The instructions call for installing fedora-30-minimal. To get networking I had to install these in fedora-30-minimal:
dnf -y install qubes-core-agent-networking qubes-core-agent-dom0-updates qubes-core-agent-passwordless-root qubes-mgmt-salt-vm-connector.
Step 4 calls for wget which I had to install:
dnf -y install wget
add networking to blackarch after you create it (in Qube setting).
SHA1 sum for strap.sh is has changed to d062038042c5f141755ea39dbd615e6ff9e23121
The instructions have an older SHA1 sum.
Feel free to propose a correction by clicking the :pencil2: on the above linked page.
edit: it may also need to be changed from fedora-30 to fedora-32 as the former has now reached EOL (end of life).
Please do keep in mind those are the community docs. And as a volunteer-lead effort don’t / can’t always have the same dedication the official ones. It’s based on improvements by people like you that they improve.
Adding network to a TemplateVM is discouraged. A better way to do it is to use the already-configured updates proxy.
Thanks. I will look into this.
Is it expected that blackarch should be a template VM?
The next step is to create a qube from this template, to actually work with?
I haven’t read those particular docs, but generally yes. The software itself is installed on a templateVM but not started there. What you do typically is then create an AppVM based on that TemplateVM and that’s where you run the programs. You can read more here:
