Installing a custom template
How do you install a custom rpm template.
Typically there’s a shell script that come when using the qubes builder.
Copy it to dom0
qvm-template install PATH_TO_TEMPLATE
If you have confirmed validity of template you can use the
--nogpgcheck option.
Otherwise, place the signing key in /etc/qubes/repo-templates/keys/ and use the –keyring` option to specify that key
