I decided to try install qubes on my laptop asus UX425E. I use USB drive for 32GB. When I try to load from this drive to installation guide of qubes firstly I see 2 screens (attached them) and then my laptop reboot. What can be wrong?
I’m the OP of that topic, and my Qubes is running well on an Intel Lake processor. I recommend visiting Index of /qubes/iso/ and installing one of the latest isos (alpha version). The one I used was from april and it’s not available anymore so try your luck with the March ones. As I said this is a Xen bug fixed from version 1.14.1.
Also don’t be afraid cause it’s an alpha OS, I’ve found out it’s super stable, works better than Ubuntu LTS
Yeah! You are right! Last test version with Qubes 4.1 has been installed successfully! Ths a lot for your response! Hope that final version 4.1 will come soon!
