The result is the same when booting in Legacy or UEFI mode.
The install USB was properly verified and used successfully to install Qubes 4.2.0 on another system (a Thinkpad T450s).
The T15 BIOS is up-to-date.
The UEFI troubleshooting docs look to be out-of-date (eg. there is no longer an EFI/BOOT/BOOTX64.cfg file to modify, just grub.cfg).
I played around with kernel parameters to no real effect. Disabling modules changed the text output a bit, but the system still froze at around the same point.
I’m unable to proceed further; the installer is stuck. Does anyone have any suggestions on what else I can try?
This is a “random” link from the forum - I don’t know if it will give you more debug information (I’ve not tried it myself) - but sounds like it could help:
Next, I installed the still supported version Qubes 4.1.2. The installation runs smoothly and the system is operational.
Then, I attempted an in-place upgrade from version 4.1 to 4.2. The reboot after Stage 1 - 3 of the installation resulted in a black screen without any error messages, and booting into the rescue system was not possible. https://www.qubes-os.org/doc/upgrade/4.2/#in-place-upgrade
Current status. My system is not compatible with Qubes 4.2, but it is fully operational under 4.1.
I don`t have any debug information regarding the in-place upgrade. The system could not be restarted. Black screen, and even the rescue system did not start.
A complete reinstallation Qubes 4.2 always hangs at:
xen_acpi_processor: Uploading Xen processor PM info
