Installation on TUXEDO InfinityBook Pro 15 - Gen9 - AMD
I am trying to install Qubes on my TUXEDO laptop (not yet listed on the HCL).
However, the installation fails (Panic on CPU 0: Xen BUG at drivers/passthrough/amd/iommu_init.c:1386), which is likely due to AMD-Vi not enabled in UEFI (?). However, I do not find the option to actually enable this; the UEFI is very minimal without any chipset config menu.
CPU: AMD Ryzen 7 8845HS w/ Radeon 780M Graphics
Motherboard: NB02 GXxHRXx
I guess it’s some issue with your CPU support:
Hi @Quoob ,
the tong fang gx4idl i bought from skikk has the same issue.
so far the support form skikk only answered me that amd-vi is enabled.
maybe you are more successful with tuxedo support.
missing is the iommu recognition, and i am not sure if xen doesnt recognize the device table correctly (device range 0x3 - 0xfffe) or the bios simply disabled it.
maybe the tuxedo bios is more complex and you find settings for AMD-VI or even IOMMU.
i am interested how tuxedo answers.
+1 I have the same tuxedo laptop, seeing the same issue
Same here. The tuxedocomputers support also told me that IOMMU is enabled…
you could try test-patched xen - worked for me.
