Hi, it’s jodi again. Forum stopped me from replying.
So created this account.
This ioapic allowed my trackpad to work. Network still not working even after fedora. Will try to troubleshoot it further.
Should I remove module blacklist parameter now? Or it need to be kept?
Most probably it’s a problem with missing firmware for your WiFi controller in sys-net template.
You’ll need to download the missing firmware from another system and manually move it to the sys-net template.
But it’s not certain that it’s an issue with firmware so it’d be better to look for errors in dmesg output in sys-net.
You should keep the module blacklist for your trackpad to work.
Correction, I’m not sure if it’s needed. If Qubes OS works without blacklisting then you can remove the blacklisting.
I don’t know whatever there is any vulnerability associated with it.
Some errors related to PCI devices. They may be printed in red color.
You need to find the messages associated with your WiFi controller.
The module blacklisting that you did to boot into Qubes OS installer was temporary and it wasn’t saved anywhere so if you didn’t add the module blacklisting in dom0 after installing Qubes OS then you don’t have it right now.
This seems to be the problem, but I’m not sure what’s wrong there. Maybe a problem with firmware of kernel driver.
What’s your WiFi controller PCI ID? Check the output of this command in dom0:
lspci -nn | grep Qualcomm
The PCI ID will be at the end in the brackets like this [XXXX:XXXX].
Then you can try to remove it during Qubes OS boot in GRUB menu for a test the same way you’ve added it for installer. If Qubes OS will boot without an issue then you can remove it from GRUB default config and update the GRUB config.
For completeness sack, 4 bin files I have put in hw2.0
I haven’t removed anything and all parameters are still there.
When I put journalctl command in sys-net, I have got no result.
My reading comprehension was bad, so I didn’t understand your question right.
To enable tap to click go to Q → gear icon → System Settings → Mouse and Touchpad
Then in the Devices tab open the Touchpad tab and you’ll see the option to enable it.
This command:
sudo journalctl -b > journalctl.log
Will create the log file in the current directory (with /home/user/journalctl.log path by default) and you can copy it from there.
You are right, it wasn’t there but after placing it towards right and reboot, issue not resolved yet. What is the next step, you are really helpful, thank you for that.
I can see your PCI ethernet controller is attached to sys-net but there is no PCI wireless controller there.
Open the sys-net Qubes Settings → Devices tab and make sure that your wireless controller is in the right column. If it’s not then move in from left column to the right column and then try to start sys-net again.
