Hi folks!
I’m trying to install qubes os for my first time. I followed the instructions on the qubes website and made a USB memory stick on an actual ubunutu linux witd dd as described. Then, I used this USB stick on an intel nuc core i5 for the installation. Setup is starting up with no problems and I can make all the settings necessary for the installation.
After ~1/3 of the installation, the installer shows a Window with the error message: «Der folgende schwerwiegende Fehler trat während der Installation auf. Hierbei handelt es sich um einen schwerwiegenden Fehler und die Installation wird abgebrochen.
DNF error: Error unpacking rpm package qubes-template-debian-10-4.0.1-201912251612.noarch»
After terminating the installation, I can only choose to start over again (what I did once with the same error on the same spot).
Can you help me how I can solve this fault and proceed with a complete installation?
Kind regards,
Dominic
