Install Problem Lenovo P72 R4.3.0
Did a bare metal install on Lenovo P72
1000 gig drive
16 gig memory
And got the following message at the end of the install:
[‘/usr/bin/qvm-start’,’sys-firewall’] failed:stdout
stderr:”Error:Start failed: internal error:Unable to reset PCI device
0000:00:1f.6:no FLR, PM reset or bus reset available, see /var/log/libvirt/libxl/libxl-driver.log for details
Can not get to the log because the individual qubes won’t run.
Messages when I try personal qube are sys-net, sys-firwall and sys-personal will not load.
Appreciate any guidance to run R4.3
I get a similar journal message in dom0 on each boot:
virtxend[4050]: internal error: Unable to reset PCI device 0000:00:14.0: no FLR, PM reset or bus reset available
I have not been digging into it as it doesn’t seem to cause any trouble. In your case it might be different. See if this helps:
Thanks for your note. Sorry for the late reply. A couple of problems I have encountered listed below. Have read over PCI trouble shooting guidance.
A-There is nothing in the file libxl-driver.log that is referenced in my original note.
B- Understand that 0000:00:1f:6 can not be used because something else is using he resource but running qvm-pci or lspci in dom0 does not help me find the cause.
C- Lenovo P72 comes with intel network card
D- Like more specific guidance on how to find the offending PCI device.
