I want to install a network- IP based - printer, which should be accessed by all Qubes Apps. What is the best strategie resp. way to achieve this ?
Installation inside the gnome environment is impossible.
Many thanks for your kind and comprehensive advice.
Thank you for your kind input - at the moment i am more confused what to do, rather then decided on how to implement the IP printer s a central device.
With that you will have a dedicated printer templateVM and a corresponding printer appVM. To keep things easy, you can simple copy any file i.e. PDF to this printer appVM (right-click on the file in the file browser; see Video tours | Qubes OS time: 5:00)
