Install first application
I would like to install my first application in Qubes Os. That would be KeePass. Unfortunately i can’t find Keepass in the package manager. Should i then install the application manually or use a third-party repository?
Keepass is available in the 3rd party repository EPEL keepass - Fedora Packages
But it seems Keepass for linux is discontinued. KeepassXC is the most modern fork that works on Linux and should be installed by default on Qubes OS in the template on a default installation IIRC.
I can confirm that it’s present in 4.1.x. In a default installation it should be available to every app VM. (It does not appear in the minimal templates [appropriately, because it shouldn’t] but is simple enough to install.)
