In-place upgrade to debian-13 fails with xen-utils-guest unmet dependency error
This is a debian-12-minimal template. I just switched its /etc/apt/sources.list contents into following:
# /etc/apt/sources.list
# enable tor
#deb https://deb.debian.org/debian trixie main contrib non-free
deb tor+http://2s4yqjx5ul6okpp3f2gaunr2syex5jgbfpfvhxxbbjwnrsvbk5v3qbid.onion/debian trixie main contrib non-free non-free-firmware
#deb https://deb.debian.org/debian-security trixie-security main contrib non-free
deb tor+http://5ajw6aqf3ep7sijnscdzw77t7xq4xjpsy335yb2wiwgouo7yfxtjlmid.onion/debian-security trixie-security main contrib non-free non-free-firmware
#Optional Backports
#deb https://deb.debian.org/debian trixie-backports main contrib non-free
deb tor+http://2s4yqjx5ul6okpp3f2gaunr2syex5jgbfpfvhxxbbjwnrsvbk5v3qbid.onion/debian trixie-backports main contrib non-free non-free-firmware
Also changed the contents of /etc/apt/sources.list.d/qubes-r4.list:
# /etc/apt/sources.list.d/qubes-r4.list
# Main qubes updates repository
#deb [arch=amd64 signed-by=/usr/share/keyrings/qubes-archive-keyring-4.2.gpg ] https://deb.qubes-os.org/r4.2/vm bookworm main
#deb-src [arch=amd64 signed-by=/usr/share/keyrings/qubes-archive-keyring-4.2.gpg ] https://deb.qubes-os.org/r4.2/vm bookworm main
# Qubes updates candidates repository
#deb [arch=amd64 signed-by=/usr/share/keyrings/qubes-archive-keyring-4.2.gpg] https://deb.qubes-os.org/r4.2/vm bookworm-testing main
#deb-src  [arch=amd64 signed-by=/usr/share/keyrings/qubes-archive-keyring-4.2.gpg ]  https://deb.qubes-os.org/r4.2/vm bookworm-testing main
# Qubes security updates testing repository
#deb [arch=amd64 signed-by=/usr/share/keyrings/qubes-archive-keyring-4.2.gpg] https://deb.qubes-os.org/r4.2/vm bookworm-securitytesting main
#deb-src  [arch=amd64 signed-by=/usr/share/keyrings/qubes-archive-keyring-4.2.gpg ] https://deb.qubes-os.org/r4.2/vm bookworm-securitytesting main
# Qubes experimental/unstable repository
#deb [arch=amd64 signed-by=/usr/share/keyrings/qubes-archive-keyring-4.2.gpg] https://deb.qubes-os.org/r4.2/vm bookworm-unstable main
#deb-src  [arch=amd64 signed-by=/usr/share/keyrings/qubes-archive-keyring-4.2.gpg ] https://deb.qubes-os.org/r4.2/vm bookworm-unstable main
# Qubes Tor updates repositories
deb [arch=amd64 signed-by=/usr/share/keyrings/qubes-archive-keyring-4.2.gpg] tor+http://deb.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r4.2/vm trixie main
#deb-src  [arch=amd64 signed-by=/usr/share/keyrings/qubes-archive-keyring-4.2.gpg ] tor+http://deb.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r4.2/vm bookworm main
#deb [arch=amd64 signed-by=/usr/share/keyrings/qubes-archive-keyring-4.2.gpg] tor+http://deb.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r4.2/vm bookworm-testing main
#deb-src  [arch=amd64 signed-by=/usr/share/keyrings/qubes-archive-keyring-4.2.gpg ] tor+http://deb.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r4.2/vm bookworm-testing main
#deb [arch=amd64 signed-by=/usr/share/keyrings/qubes-archive-keyring-4.2.gpg] tor+http://deb.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r4.2/vm bookworm-securitytesting main
#deb-src  [arch=amd64 signed-by=/usr/share/keyrings/qubes-archive-keyring-4.2.gpg ] tor+http://deb.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r4.2/vm bookworm-securitytesting main
#deb [arch=amd64 signed-by=/usr/share/keyrings/qubes-archive-keyring-4.2.gpg] tor+http://deb.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r4.2/vm bookworm-unstable main
#deb-src  [arch=amd64 signed-by=/usr/share/keyrings/qubes-archive-keyring-4.2.gpg ] tor+http://deb.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r4.2/vm bookworm-unstable main
I do a apt update as the root user, and I get 422 packages upgradable. I do apt upgrade as the root user and get the following error message:
Reading package lists...
Building dependency tree...
Reading state information...
Calculating upgrade...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 xen-utils-guest : Conflicts: xen-hypervisor-common but 4.20.0+68-g35cb38b222-1 is to be installed
Weirdly enough, I don’t see xen-hypervisor-common package installed on this minimal template:
xen-hypervisor-common:
  Installed: (none)
  Candidate: 4.20.0+68-g35cb38b222-1
  Version table:
     4.20.0+68-g35cb38b222-1 500
        500 tor+http://2s4yqjx5ul6okpp3f2gaunr2syex5jgbfpfvhxxbbjwnrsvbk5v3qbid.onion/debian trixie/main amd64 Packages
neither is it among the upgradable packages list:
xdg-utils/stable 1.2.1-2 all [upgradable from: 1.1.3-4.1]
xen-utils-common/stable 4.20.0+68-g35cb38b222-1 amd64 [upgradable from: 4.17.5+23-ga4e5191dc0-1+deb12u1]
xen-utils-guest/unknown 5.0.4-1+deb13u1 amd64 [upgradable from: 5.0.4-1+deb12u1]
xenstore-utils/stable 4.20.0+68-g35cb38b222-1 amd64 [upgradable from: 4.17.5+23-ga4e5191dc0-1+deb12u1]
xinit/stable 1.4.2-1 amd64 [upgradable from: 1.4.0-1]
Well, what’s going on? How may I fix this and upgrade in-place my minimal debian template from 12 to 13?
Try apt dist-upgrade. As far as I remember, the apt upgrade also failed for me, but a dist-upgrade worked.
I will try apt dist-upgrade. But I would also like to hear a concrete opinion about this xen-hypervisor-common dependency.
Edit: I am doing a apt full-upgrade as the root user and the packages are being downloaded for the updating.
just skipping apt upgrade for apt dist-upgrade worked for me (was getting same error as @tanky0u). Wonder if that should be removed from the update instructions?
Or should one run apt upgrade before changing your apt repos? Why would it be helpful after changing repos to new version and before dist-upgrade?
