In-place upgrade from 4.1 to 4.2 fails whonix-16 InRelease is expired
So upgrade on 4.1 for whonix-gw-16 and whonix-ws-16 fail. Repository tor+https://…InRelease is expired (invalid for 118d…
qubes-dist-upgrade also fails on stage1 because of the same error.
Kinda silly that upgrade fails because old version is not supported anymore? Isn’t that why people upgrade? Is there a way to push through this or are you screwed if you don’t upgrade inside the window? I have few qubes that use whonix-ws-16 as a template.
You can easily update Whonix 16 to Whonix 17, and then update. Just look into Whonix/Kicksecure in-place upgrades.
