IMSI / IMEI catchers
does qubes os also block IMSI or IMEI catchers?
I don’t think you can block IMSI or IMEI.
IMSI is the SIM id, without a valid id you can can’t connect to the GSM network.
You can get hardware that can change the IMEI, but believe it’s all done in the firmware, not by the OS/software.
