Hi there,
I’m trying to install an icon theme(tried many) on my debian 12 xfce template, but each time it seems like some apps(brave, librewolf and others) don’t respect the icon theme and use their own icons instead, while other apps(xfce4-terminal, firefox) use new icons of the selected icon theme.
Any ideas of how to fix this?
have you also tried to manually apply the theme to the AppVM ?
I tried many things.
What do you mean exactly?
In exemple by changing the theme with gsettings command or by running the gui setting of xfce xfce4-appearance-setttings. Are you shure this themes include this icons ?
I am sure.
The themes are in the right place - /usr/share/icons/
Also, the effect is in place, hence other icons(thunar, xfce4-terminal etc) are changed.
I also use full icon themes such as papirus, so all the icons I mentioned should take effect too, but they are not.
I don’t know if its related but you can try gtk-update-icon-cache /usr/share/icons/*YourThemeName*. Try to install it on $HOME/.icons/ and rerun the update cache command.
I tired that many times, sadly with no results.
So full icon packs like papirus works for you even with brave/librewolf with no issues?
It works for me after converting with ImageMagick and manually replacing the image in the corresponding template (fedora-41-xfce here).
convert -background none /usr/share/icons/Papirus/16x16/apps/librewolf.svg $HOME/.local/share/qubes-appmenus/fedora-41-xfce/apps.tempicons/librewolf.png
qvm-appmenus --update fedora-41-xfce
