Is there a model # I should use to be sure I am buying the correct one?
Thanks,
Mike
Intel Core i7 3840QM CPU Quad-Core 2.8-3.8GHz 8M SR0UT Socket G2 Processor
Hi, New to the list and not a tech guy. I am in the process of purchasing a T430 and am looking to upgrade the CPU to i73840QM. Most of the used ones seem to originate in China. Given the following description, what is SROUT. Some of the descriptions have that term and others don't.
It is the cpuid https://www.cpu-world.com/sspec/SR/SR0UT.html
Right…and what is a SR0UT CPUID ?
Cheers,
The physical CPU will have SR0UT as part of the information printed on the CPU. SR0UT is the sample number, it tells you in which batch run the CPU was produced.
Don’t know if the number matters, but I don’t think so.
Thanks…much appreciated.
If some post solved it for you, please mark it as a solution so it could help others too. Thanks.
Thanks, but it can’t be mine post, hahah. It’s some of the @renehoj’s posts.
