I2pd netvm based on debian guide
This guide demonstrates how to set up i2pd as a netvm, allowing you to easily proxy traffic through the i2p network to access the clearnet or i2p services. This significantly enhances security and privacy.
This method is an improved implementation compared to I2pd netvm guide, utilizing debian-12 and avoiding the outdated i2pd-qt and archlinux community template.
Installation
  1. First, you need a debian-12-xfce template VM.
  2. Clone this template and name it debian-12-xfce-i2pd.
Execute the following commands within the debian-12-xfce-i2pd :
sudo apt install wget
wget -q -O - https://repo.i2pd.xyz/.help/add_repo | sudo bash -s -
sudo apt update
sudo apt install i2pd
This utilizes the i2pd team’s repository, which automatically provides the latest i2pd version.
  1. Proceed to install clash-verge-rev:
Visit Releases · clash-verge-rev/clash-verge-rev · GitHub to find the appropriate version of clash-verge-rev. This guide uses the latest stable version, v2.0.2. Ensure your debian-12-xfce-i2pd VM has a suitable netvm configured for internet access (you can download the .deb in another VM and transfer it to debian-12-xfce-i2pd).
wget https://github.com/clash-verge-rev/clash-verge-rev/releases/download/v2.0.2/Clash.Verge_2.0.2_amd64.deb
sudo apt install ./Clash.Verge_2.0.2_amd64.deb
shutdown now
Creating New appvm
Creating sys-i2pd-out
Execute the following commands within sys-i2pd-out:
sudo systemctl enable i2pd.service
sudo nft add rule ip qubes custom-input meta l4proto tcp ct state new,established tcp dport 4500 accept
Wait 10-20 minutes for i2pd to start accepting connections.
In another terminal tab, run the following command for simple monitoring:
watch curl --socks5-hostname 127.0.0.1:4447 acetone.i2p
Proceed to the next step once the above command receives a response.
Modifying Startup Commands
  1. Paste the following into /rw/config/rc.local:
#!/bin/bash
  1. Add the following to /rw/config/qubes-bind-dirs.d/50_user.conf:
binds+=( '/etc/i2pd' )
  1. Restart the sys-i2pd-out VM.
  2. Paste the following into /etc/i2pd/tunnels.conf:
[socks-outproxy-tcp]
type = client
address = 0.0.0.0
port = 4500
keys = transient-outproxy
destination = outproxy.acetone.i2p
destinationport = 1080
inbound.length = 1
outbound.length = 1
inbound.lengthVariance = 1
outbound.lengthVariance = 1
[socks-outproxy-udp]
type = udpclient
address = 127.0.0.1
port = 4500
You can modify some of these parameters if you need to use a different outproxy.
  1. Add the following to the [socksproxy] section of /etc/i2pd/i2pd.conf:
outproxy.enabled = true
outproxy = 127.0.0.1
outproxyport = 4500
Creating sys-i2pd-in
Open a terminal and type clash-verge to launch the application.
  1. Create a new profile in the Clash Verge application:
  2. Edit proxy settings:
  3. Enable the proxy in Proxies > Global.
  4. Enable autostart in Setting > System Setting > Auto Launch.
Adding Firewall Rules (Kill Switch)
Execute the following commands in dom0:
qvm-firewall sys-i2pd-in reset
qvm-firewall sys-i2pd-in add accept <sys-i2pd-out-ip-here> dstports=4500 proto=tcp
qvm-firewall sys-i2pd-in del --rule-no 0
Additional Information
Verification
Create a new test VM and select sys-i2pd-in as its netvm to verify network functionality. You should be able to access both .i2p services and the clearnet.
Donation
I’m still considering this.
References
Unofficial Qubes OS Discussion Group
Welcome to join!
https://matrix.to/#/#chat:qubes.live
This doesn’t work for me. not sure why. I’ve triple checked that everything is exact but it still doesn’t work.
Hi, thank you for your guides!
I am unable to get connection in sys-i2pd-in. I can access the i2p console & eepsites in sys-i2pd-out, but once I enable the clash verge global proxy in sys-i2pd-in I have no connection
I remade the qubes a couple times, and I actually tried this back when you posted the archlinux version and failed there too
hopeful we can get this figured out
The problem may be that you didn’t enter the IP address of sys-i2pd-out correctly,If you can use Telegram, please come to Telegram: Contact @qubeszh with me
Please ignore the archlinux template in the image I borrowed, in fact I use the debian template, and I will fix this error
If you can’t solve this problem, you can solve it online with me at Telegram: Contact @qubeszh
Accessing non i2p sites through i2p has nothing with improving security and privacy, IMO.
Why not?
why ,the target website only knows outproxy
I’m stuck on:
for some reason it throws error:
Error: Could not process rule: No such file or directory
what do I need to do?
What’s the template of the qube in which you try to run this command?
Check the output of this command and see if you have a ip qubes custom-input chain:
sudo nft list ruleset
  1. debian-13-minimal (what did they cut from minimal qubes?)
  2. nft list outputs nothing
Did you install the qubes-core-agent-networking package in your minimal template?
it’s preinstalled there
The qubes-core-agent-networking package is not preinstalled in minimal templates.
well, I guess it got installed on update or something
anyway, yes, it is installed on my i2p template qube.
If this command returns no output:
Then something is broken in your template.
Recreate your i2p template from the original debian-13-minimal template step-by-step and find out which step breaks your firewall.
I didn’t tamper with original debian-13-minimal template but “sudo nft list ruleset” still returns nothing even there
oh, now I get it
what’s the command to show installed packages on Debian?
