I think my isp is throttling my whonix connections
My personal qube internet is working fine, however my qubes that are routed through says-whonix keeps moving slow and I have to be restarting my tor connection for it to work for a bit and goes back to moving slow or no connection at all. I tried using bridges and it’s the same issue. Is there any recommendations I can try?
Does your ISP also throttle VPN’s?
If not, you could sys-whonix -> sys-VPN -> sys-net
