I would start with that none of these are unworkable I am writing this to help the devs improve qubes more than look for fixes but I didn’t think it was worthy of a bug report either. Any way hope this helps someone.
However I would like the command to get the mouse to be recognized. If I am using the wrong one.
fails to boot at all, This varies from not even getting the graphics card running and displaying the drive decrypt. To failing to open the Hard drive. It’s not often but the janky fix is to cut power at the PSU for a few minutes. This works for the first one. The fix for the second is just to reboot.
The sys-usb is not recognizing the mouse at all on some boots. This fixes with a reboot. Or, I have had a few times where I put the machine to sleep and then, on wake. It fails to pop up the window allowing me to connect the mouse. Poping a terminal and using the command sys-usb ls shows the mouse just fine. I probably just don’t know the command to to get it working. I have been trying qvm-usb attach dom0 BACKEND:DEVID. That simply did not work for me. It returns no error but fixes nothing.
An, the final one is workstation and whonix-gate way have been failing to update this had happened once before for The workstation I think. It kinda self fixed after a week. I will post those reports under system specs.
Specs:
Mother board Is Asus Sabertooth 990FX R2.0
Processor is 9590 fx eight core
Ram 32gb crucial on 4/8 gb sticks
Updating whonix-gateway-17
Refreshing package info
Refreshing available packages.
Fail to refresh InRelease: tor+https://deb.whonix.org bookworm InRelease from gpgv:/var/lib/apt/lists/partial/deb.whonix.org_dists_bookworm_InRelease
Fail to refresh InRelease: tor+https://deb.kicksecure.com bookworm InRelease from gpgv:/var/lib/apt/lists/partial/deb.kicksecure.com_dists_bookworm_InRelease
Refreshed.
W:An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: tor+https://deb.whonix.org bookworm InRelease: The following signatures were invalid: EXPKEYSIG CB8D50BB77BB3C48 Patrick Schleizer adrelanos@kicksecure.com, W:An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: tor+https://deb.kicksecure.com bookworm InRelease: The following signatures were invalid: EXPKEYSIG CB8D50BB77BB3C48 Patrick Schleizer adrelanos@kicksecure.com, E:Failed to fetch tor+https://deb.kicksecure.com/dists/bookworm/InRelease The following signatures were invalid: EXPKEYSIG CB8D50BB77BB3C48 Patrick Schleizer adrelanos@kicksecure.com, E:Failed to fetch tor+https://deb.whonix.org/dists/bookworm/InRelease The following signatures were invalid: EXPKEYSIG CB8D50BB77BB3C48 Patrick Schleizer adrelanos@kicksecure.com, E:Some index files failed to download. They have been ignored, or old ones used instead.
Hit:1 tor+https://deb.debian.org/debian bookworm InRelease
Hit:2 tor+https://fasttrack.debian.net/debian-fasttrack bookworm-fasttrack InRelease
Get:3 tor+https://deb.kicksecure.com bookworm InRelease [62.0 kB]
Get:4 tor+https://deb.whonix.org bookworm InRelease [61.2 kB]
Hit:5 Index of /r4.2/vm/ bookworm InRelease
Err:3 tor+https://deb.kicksecure.com bookworm InRelease
Hit:6 tor+https://deb.debian.org/debian bookworm-updates InRelease
Err:4 tor+https://deb.whonix.org bookworm InRelease
Hit:7 tor+https://fasttrack.debian.net/debian-fasttrack bookworm-backports-staging InRelease
Hit:8 tor+https://deb.debian.org/debian-security bookworm-security InRelease
Hit:9 tor+https://deb.debian.org/debian bookworm-backports InRelease
Reading package lists…
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: tor+https://deb.kicksecure.com bookworm InRelease: The following signatures were invalid: EXPKEYSIG CB8D50BB77BB3C48 Patrick Schleizer adrelanos@kicksecure.com
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: tor+https://deb.whonix.org bookworm InRelease: The following signatures were invalid: EXPKEYSIG CB8D50BB77BB3C48 Patrick Schleizer adrelanos@kicksecure.com
E: Failed to fetch tor+https://deb.kicksecure.com/dists/bookworm/InRelease The following signatures were invalid: EXPKEYSIG CB8D50BB77BB3C48 Patrick Schleizer adrelanos@kicksecure.com
E: Failed to fetch tor+https://deb.whonix.org/dists/bookworm/InRelease The following signatures were invalid: EXPKEYSIG CB8D50BB77BB3C48 Patrick Schleizer adrelanos@kicksecure.com
E: Some index files failed to download. They have been ignored, or old ones used instead.
Updating whonix-workstation-17
Refreshed.
W:An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: tor+https://deb.kicksecure.com bookworm InRelease: The following signatures were invalid: EXPKEYSIG CB8D50BB77BB3C48 Patrick Schleizer adrelanos@kicksecure.com, W:An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: tor+https://deb.whonix.org bookworm InRelease: The following signatures were invalid: EXPKEYSIG CB8D50BB77BB3C48 Patrick Schleizer adrelanos@kicksecure.com, E:Failed to fetch tor+https://deb.kicksecure.com/dists/bookworm/InRelease The following signatures were invalid: EXPKEYSIG CB8D50BB77BB3C48 Patrick Schleizer adrelanos@kicksecure.com, E:Failed to fetch tor+https://deb.whonix.org/dists/bookworm/InRelease The following signatures were invalid: EXPKEYSIG CB8D50BB77BB3C48 Patrick Schleizer adrelanos@kicksecure.com, E:Some index files failed to download. They have been ignored, or old ones used instead.
Hit:4 Index of /r4.2/vm/ bookworm InRelease
Get:5 tor+https://deb.whonix.org bookworm InRelease [61.2 kB]
Err:5 tor+https://deb.whonix.org bookworm InRelease
Any way hope this helps some-one makes qubes better. If I put it in the wrong place please let me know where I should send it thanks.
