I’m trying to get wyng backup 04alpha2 working. Maybe I’m misunderstanding how to use it.
I git cloned the project in a disposable VM, git checkout'd to 04alpha2, and then copied to dom0 the Python executable and the other scripts in the misc directory.
Then, in dom0, I tried running wyng:
[user@dom0 wyng-backup]$ ./wyng --local=myvg/mypool --dest=qubes://admin-backups/media/veracrypt1/backups/wyng/ --encrypt=xchacha20-poly1305 --verbose arch-init
ERROR: wyng is already running.
But wyng isn’t running according to ps aux.
I also tried with sudo:
[user@dom0 wyng-backup]$ sudo ./wyng --local=myvg/mypool --dest=qubes://admin-backups/media/veracrypt1/backups/wyng/ --encrypt=xchacha20-poly1305 --verbose arch-init
Wyng 0.4.0alpha2 release 20220903
File "./wyng", line 3346, in <module>
aset, dest = get_configs(options)
File "./wyng", line 1113, in get_configs
arch_init(aset)
TypeError: arch_init() missing 1 required positional argument: 'opts'
I don’t know if myvg needs to exists, but I tried creating and deleting it. Same with myvg/mypool, which I assume is a directory.
I’m probably missing something. What is it?
