Ive set up a HMV with a webserver installed and tor installed with a hidden service setup and working.
I can access the website via the v3 .onion address from aother qube fine, when im using the firewall for networking however…
When I switch to whonix for networking, change the ip setting to match on the hmv and check im connected to tor using the browser in the hmv it works BUT i then cannot access the .onion address.
Any suggestions?
How can this be set up correctly? Is there a something like a torrc file in whonix gateway that i can point to the internal IP of my hvm? Then i assume i would purge tor from the hvm. Am i along the right lines here. I cant seem to fine any guides on what i am trying to achieve without using a whonix workststion.
The reason i am using a hvm running ubuntu 18.04 is because i am struggling to install the correct depedencies and versions of nodejs, npm, and mysql that ive spent hours trying to configure on a whonix workstation but ive givennup.
You can set up onion service in sys-whonix and just use your HVM instead of Whonix-Workstation:
http://www.dds6qkxpwdeubwucdiaord2xgbbeyds25rbsgr73tbfpqpt4a6vjwsyd.onion/wiki/Onion_Services
Clearnet link:
