HP ENVY x360 (15-dr1xxx)
layout:
  'hcl'
type:
  'convertible'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  'unknown'
remap:
  'yes'
brand: |
  HP
model: |
  HP ENVY x360 Convertible 15-dr1xxx
bios: |
  F.10
cpu: |
  Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz
cpu-short: |
  i7-1051OU
chipset: |
  Intel Corporation Comet Lake-U v1 4c Host Bridge/DRAM Controller [8086:9b61] (rev 0c)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation CometLake-U GT2 [UHD Graphics] [8086:9b41] (rev 02) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Comet Lake PCH-LP CNVi WiFi
memory: |
  16043
scsi: |
usb: |
  1
versions:
- works:
    'yes'
  qubes: |
    R4.1
  xen: |
    4.14.2
  kernel: |
    5.10.47-1
  remark: |
    Works perfectly expect that LAN driver isn't recognized with default installation.
  credit: |
    PMB-NL
  link: |
    FIXLINK
Remarks
Installation of 4.1 goes without errors. Only remark is that LAN driver isn’t recognized by default. Also if I select Debian as default also the WLAN driver isn’t recognized. I fixed that by using Fedora template for sys-net.
Any suggestions to get the LAN adapter working would be appriciated.
With 16GB and Intel i7 CPU the performance is really good.
Because my old ASUS laptop wasn’t usable anymore I installed Qubes OS on this laptop that actually was my only personal Windows laptop so my challenge to make this work is increased. :wink:
The laptop includes a i7-1051OU CPU.
I wanted to check the specifications using an Intel chip recognition tool. Strange thing is that this tool shows less features than the processor actually supports. Really weird. On the ARC section of Intel site these features are shown properly.
Awesome HCL contributions you’ve been doing :slight_smile:
Thank you @pmb-nl for all of your HCL reports! This one too is now part
of this pull request:
… and will be visible on the website soon!
