HP EliteBook 840 G10
layout:
  'hcl'
type:
  'Notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  HP
model: |
  HP EliteBook 840 14 inch G10 Notebook PC
bios: |
  V70 Ver. 01.09.00
cpu: |
  13th Gen Intel(R) Core(TM) i7-1355U
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Raptor Lake-P/U 2p+8e cores Host Bridge/DRAM Controller [8086:a708] (rev 01)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation Raptor Lake-P [Iris Xe Graphics] [8086:a7a1] (rev 04) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Raptor Lake PCH CNVi WiFi [8086:51f1] (rev 01)
memory: |
  32400
scsi: |
usb: |
  4
certified:
  'no'
versions:
  - works:
      'FIXME:yes|no|partial'
    qubes: |
      R4.3-rc2
    xen: |
      4.19.3
    kernel: |
      6.12.47-1
    remark: |
      FIXME
    credit: |
      FIXAUTHOR
    link: |
      FIXLINK
Remarks
Partitioned by hand using the advanced options as there are multiple OS on this laptop and this qubes instalation which went into 70GB partition with ext4 format is for testing only.
Multibooting is not a problem thanks to grub which is on the machine due to kali.
Changed boot order in efi accordingly to boot the grub of the kali linux installation on this laptop. Update-grub of kali found qubes-os automatically. Using unencrypted qubes on ext4 partition as / for testing.
Qubes-OS-4.3 RC3:
Suspend to RAM does not work:
The screen is dark for longer time, and the screen gets lit only after mouse movement.
The build-in keyboard of the laptop does not work, so login into the lock-screen does not work.
I wish there would be a sync-button in the lock-screen as I had to hard switch-off the laptop (press power for longer time, the chipset then issues power-off)
layout:
  'hcl'
type:
  'Notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  HP
model: |
bios: |
  V70 Ver. 01.10.00
cpu: |
  13th Gen Intel(R) Core(TM) i5-1335U
cpu-short: |
  FIXME
chipset: |
chipset-short: |
  FIXME
gpu: |
  Intel Corporation Raptor Lake-P [UHD Graphics] [8086:a721] (rev 04) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
memory: |
  16016
scsi: |
usb: |
  4
certified:
  'no'
versions:
  - works:
    qubes: |
      R4.3.0
    xen: |
      4.19.4
    kernel: |
      6.12.63-1
    remark: |
      FIXME
    credit: |
      FIXAUTHOR
    link: |
      FIXLINK
Remarks
First installation request troubleshooting to get disk write permission:
HVM qube for LTE modem fail to start with error:
internal error: Unknown PCI header type '127'
