layout:
'hcl'
type:
'Notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'2.0'
remap:
'yes'
brand: |
HP
model: |
HP Dragonfly 13.5 inch G4 Notebook PC
bios: |
V90 Ver. 01.03.01
cpu: |
13th Gen Intel(R) Core(TM) i7-1355U
cpu-short: |
FIXME
chipset: |
Intel Corporation Raptor Lake-P/U 2p+8e cores Host Bridge/DRAM Controller [8086:a708] (rev 01)
chipset-short: |
FIXME
gpu: |
Intel Corporation Raptor Lake-P [Iris Xe Graphics] [8086:a7a1] (rev 04) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Raptor Lake PCH CNVi WiFi [8086:51f1] (rev 01)
memory: |
32336
scsi: |
usb: |
4
certified:
'no'
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.2.0
xen: |
4.17.2
kernel: |
6.6.2-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
Remarks
Installation
No issues with installation. Used the latest kernel option, but not sure if it’s required.
Thoughts
Great keyboard, great build. good battery life (7+ Hours in my normal use). Couldn’t get S3 sleep to work. Wish there were more i7-1355u laptops out there that can be used with Qubes. or any that support S3!
Basic Input
Works
- Keyboard
- Touch-pad
- Touch-pad supports “tap as click” and scrolling with 2 fingers works
- Display brightness change shortcuts
- Sound volume shortcuts,
- Keyboard led and keyboard brightness change shortcuts,
- Keyboard and touchpad use PS/2
Untested
USB Mouse
Internet and bluetooth
- No Ethernet Port
- Wifi works out of the box
- Wifi Stable
- Bluetooth untested
Suspend
Suspend does not work. Laptop exposes S3 support and will go to sleep. However, laptop takes 1-2 minutes to wake up and keyboard does not work when it does. I spent the good part of a day digging into this and couldn’t find a solution.
Audio
- sound from speakers works fine. rest untested.
Fans
- Fans silent during normal use.
Other
- Did not test Windows HVM
- Boost appears to work (performance would be really bad without it on a u series chip). However, I’m unsure how to get real cpu frequency readings. My troubleshooting with past laptops lead me to believe that Xen will always lie to me.
Specs:
- HP Dragonfly G4 Customization Page
- 1920x1280 (13.5" 3:2 Screen). 3000x2000 OLED screen also available
- Max Memory - 32GB
- PassMark CPU Score (Generic, not tested specific model): 15369
- 4 USB Controllers. 2 USB-C Ports, 1 USB-A Port
- Internal TPM
xinput --list
|⎡ Virtual core pointer |id=2|[master pointer (3)]|
|⎜ ↳ Virtual core XTEST pointer |id=4|[slave pointer (2)]|
|⎜ ↳ SYNA310F:00 06CB:CEA9 Mouse |id=9|[slave pointer (2)]|
|⎜ ↳ SYNA310F:00 06CB:CEA9 Touchpad |id=10|[slave pointer (2)]|
|⎜ ↳ ELAN2513:00 04F3:41A8 |id=11|[slave pointer (2)]|
|⎣ Virtual core keyboard |id=3|[master keyboard (2)]|
| ↳ Virtual core XTEST keyboard |id=5|[slave keyboard (3)]|
| ↳ Power Button |id=6|[slave keyboard (3)]|
| ↳ Video Bus |id=7|[slave keyboard (3)]|
| ↳ Sleep Button |id=8|[slave keyboard (3)]|
| ↳ Intel HID events |id=12|[slave keyboard (3)]|
| ↳ Intel HID 5 button array |id=13|[slave keyboard (3)]|
| ↳ AT Translated Set 2 keyboard |id=14|[slave keyboard (3)]|
| ↳ HP WMI hotkeys |id=15|[slave keyboard (3)]|
Oh, and for those wondering I get errors like this when I wake up the laptop:
ACPI: PM: Waking up from system sleep state S3
ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20221020/evregion-300)
ACPI Error: Timeout from EC hardware or EC device driver (20221020/evregion-310)
ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.ITLB due to previous error (AE_TIME) (20221020/psparse-529)
ACPI Error: Aborting method \HWAK due to previous error (AE_TIME) (20221020/psparse-529)
ACPI Error: Aborting method \_WAK due to previous error (AE_TIME) (20221020/psparse-529)
ACPI Error: AE_TIME, While executing method \_WAK (20221020/hwesleep-47)
I wasn’t able to get a DSDT table extracted that was compilable, so I gave up on it.
