Thanks for being there. Unfortunately, still no luck:
[user@dom0 ~]$ sudo rpm --import /etc/pki/rpm-gpg/RPM-GPG-KEY-unman
[user@dom0 ~]$ sudo qubes-dom0-update --action=upgrade
Using cacher as UpdateVM for Dom0
Downloading updates. This may take a while…
3isec Qubes Dom0 Repository (updates) 525 B/s | 1.5 kB 00:02
Fedora 41 - x86_64 3.2 kB/s | 4.6 kB 00:01
Fedora 41 - x86_64 - Updates 1.1 kB/s | 4.5 kB 00:04
Qubes OS Contrib Repository for dom0 (updates) 1.1 kB/s | 1.5 kB 00:01
Qubes Host Repository (updates) 1.4 kB/s | 3.2 kB 00:02
Qubes Host Repository (updates-testing) 2.0 kB/s | 3.4 kB 00:01
Qubes Host Repository (updates-testing) 84 kB/s | 632 kB 00:07
Qubes Host Repository (security-testing) 3.5 kB/s | 3.6 kB 00:01
Dependencies resolved.
Transaction Summary
Install 3 Packages
Upgrade 11 PackagesTotal size: 138 M
Total download size: 186 k
DNF will only download packages for the transaction.
Downloading Packages:
[SKIPPED]
[SKIPPED]
[SKIPPED]
Already downloaded
Total 46 kB/s | 186 kB 00:04
error: Verifying a signature using certificate 4B1F400DF25651B53C4141B38B3F30F9C8C0C2EF (unman (Qubes OS signing key) unman@thirdeyesecurity.org):
Key FDD1B8244731B36C invalid: key is not alive
because: The subkey is not live
because: Expired on 2022-06-30T14:18:58Z
3isec Qubes Dom0 Repository (updates) 1.3 MB/s | 14 kB 00:00
GPG key at file:///var/lib/qubes/dom0-updates/etc/pki/rpm-gpg/RPM-GPG-KEY-unman (0xC8C0C2EF) is already installed
The GPG keys listed for the “3isec Qubes Dom0 Repository (updates)” repository are already installed but they are not correct for this package.
Check that the correct key URLs are configured for this repository.. Failing package is: 3isec-qubes-cacher-1.17-1.fc41.x86_64
GPG Keys are configured as: file:///var/lib/qubes/dom0-updates/etc/pki/rpm-gpg/RPM-GPG-KEY-unman
Public key for 3isec-qubes-task-manager-1.0-1.x86_64.rpm is not trusted. Failing package is: 3isec-qubes-task-manager-1.0-1.x86_64
GPG Keys are configured as: file:///var/lib/qubes/dom0-updates/etc/pki/rpm-gpg/RPM-GPG-KEY-unmanTry to add ‘–enableplugin=expired-pgp-keys’ to resolve the problem. Note: This plugin might not be installed by default, as it is part of the ‘dnf-plugins-core’ package.
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing ‘dnf clean packages’.
Error: GPG check FAILED
Is there any other option I am left with? It was in-place upgrade if that matters and your repo was not upgraded automatically, which I suspect caused all of this fuss. I have the same issue with contrib repo, not being automatically upgraded, so I did that for both manually.
