How to verify Unman's template
I donwloaded unman’s template. Before I copy it to dom0. I want to sure the template is ok.
I downloaded unman’s public key.
TLDR -
rpmkeys --import PATH_TO_KEY
rpm -K PATH_TO_PACKAGE
If all is well, you will see “digests signatures ok”
Verifying a package
How do you verify any package?
In Fedora, you can see which key signed a package using rpm -qi PATH_TO_PACKAGE
For example if you have downloaded an rpm package to Downloads, and
you are in /home/user, you can run rpm -qi ./Downloads/PACKAGE_NAME
In the output the Signature line shows you the signing key ID - for
packages signed by me this may look like this:
Signature : RSA/SHA512, Tue 21 Feb 2023 10:56:59 UTC, Key ID fdd1b8244731b36c
If you have my PGP key, and have assured yourself that it is the right
key
, import it, and then check the ID:
gpg --import unman.key
gpg --edit-key unman
The output should look like this:
pub  rsa4096/8B3F30F9C8C0C2EF
     created: 2016-06-25  expires: never       usage: SC
     trust: unknown       validity: unknown
sub  rsa4096/6233CD8FA59A87A8
     created: 2016-06-25  expires: never       usage: E
sub  rsa4096/FDD1B8244731B36C
     created: 2016-06-27  expires: 2024-06-30  usage: S
[ unknown] (1). unman (Qubes OS signing key) <unman@thirdeyesecurity.org>
So the package is signed by the sub key - sub rsa4096/FDD1B8244731B36C
Checking a rpm with rpm -K
You can import the key in to the rpm keyring- rpmkeys --import PATH_TO_KEY,
and check the package using rpm -K PATH_TO_PACKAGE
This will check the digests of the package and that it is signed by a
known key.
Now you should feel pretty confident that this package is as built and
is signed by my key, and can copy the package in to dom0.
You can go through the same process after copying my key and the package
in to dom0. (In fact, you probably should do so.)
Copying a package in to dom0
This is covered here
If you have downloaded PACK.rpm to Downloads in a qube called disp9999,
in dom0 run
qvm-run -p disp9999 'cat Downloads/PACK.rpm' > PACK.rpm
Installing a downloaded template
To install in dom0, copy my key in to /etc/qubes/repo-templates/keys.
Install the package with qvm-template --keyring /etc/qubes/repo-templates/keys/KEY_NAME install PATH_TO_TEMPLATE_PACKAGE
replacing KEY_NAME with whatever name you gave my key and PATH_TO_TEMPLATE_PACKAGE with the actual path to the package.
Thanks, the guide at Index of /Templates_4.1 had the wrong command with “qvm-template install --keyring /etc/pki/rpm-gpg/RPM-GPG-KEY-unman FULL_PATH_TO_DOWNLOADED_TEMPLATE”. Changing the install position fixed it.
Thanks. I’d fixed that in the Templates page, but missed that.
No problem! And thank you so much for your templates! Without you QubesOS would be so much more frustrating to work with so I appreciate it at lot!
probably a silly question but how do you get a copy of the key to use the templates?
i see the key on qubes.3isec.org but im confused how to make use of it in text form i guess…the key concept eludes me so im lost on how to procede. the rest of the guide seems straightforward i think but getting started involes the key stuff.
Alright, you need to look how “GPG” (or “PGP”) works. You can take a look at the Qubes OS documentation as an example:
welp, this is probably really really helpful…I have never been so confused lol. i have a signiture now as a .asc file. everytime i try the gpg commands it pretends its not there. qubes is truly humbling
I cant help because you dont say what gpg commands you are trying to
use.
If you have downloaded the key, you can check the fingerprint matches
that on the website, or on GitHub, or on the mailing list. The
instruction to do this is on qubes.3isec.org-
gpg -n --import --import-options import-show KEY_YOU_DOWNLOADED
When you are satisfied, copy the key to dom0, and move it in to place.
This is explained at https://qubes.3isec.org/Templates/
Once you have the signing key you can use it to validate template
packages, as explained on that page. If you cant follow the
instructions, let me know what is unclear or what is failing.
when trying to move the key to dom0 using `qvm-template --keyring /etc/qubes/repo-templates/keys/RPM-GPG-KEY-unman install FULL_PATH_TO_DOWNLOADED_TEMPLATE’ and for the path i use /home/tbed/kali-core
feel like im missing something simple
it just keeps saying it cannot find the template file but that sucker is there.
tried the other way too, making the file and using the template gui. fails the template search everytime…
Are you sure that the file FULL_PATH_TO_DOWNLOADED_TEMPLATE is a correct rpm file?
If you don’t provide the error messages, we can’t help you.
what you just said clicked it for me…i moved the template file to dom0 but didnt mark it as an rpm file…like an idiot. its all working now. sorry for the bother
And @unman’s key just expired a week ago, or I am missing something?
Yes.
The key was extended prior to expiration. Just pull down a fresh copy
from a keyserver or my GitHub.
Weird. I did that several times in the last few days, and I’m still stuck
[user@dom0 ~]$ gpg --import --import-options import-show ./unman.asc
pub rsa4096 2016-06-25 [SC]
4B1F400DF25651B53C4141B38B3F30F9C8C0C2EF
uid unman (Qubes OS signing key) unman@thirdeyesecurity.org
sub rsa4096 2016-06-27 [S] [expires: 2027-06-30]
sub rsa4096 2016-06-25 [E]
gpg: Total number processed: 1
gpg: unchanged: 1
[user@dom0 ~]$ sudo cp ./unman.asc /etc/pki/rpm-gpg/RPM-GPG-KEY-unman
[user@dom0 ~]$ sudo qubes-dom0-update --action=upgrade
error: Verifying a signature using certificate 4B1F400DF25651B53C4141B38B3F30F9C8C0C2EF (unman (Qubes OS signing key) unman@thirdeyesecurity.org):
Key FDD1B8244731B36C invalid: key is not alive
because: The subkey is not live
because: Expired on 2022-06-30T14:18:58Z
3isec Qubes Dom0 Repository (updates) 14 MB/s | 14 kB 00:00
GPG key at file:///var/lib/qubes/dom0-updates/etc/pki/rpm-gpg/RPM-GPG-KEY-unman (0xC8C0C2EF) is already installed
The GPG keys listed for the “3isec Qubes Dom0 Repository (updates)” repository are already installed but they are not correct for this package.
Check that the correct key URLs are configured for this repository.. Failing package is: 3isec-qubes-cacher-1.17-1.fc41.x86_64
GPG Keys are configured as: file:///var/lib/qubes/dom0-updates/etc/pki/rpm-gpg/RPM-GPG-KEY-unman
Public key for 3isec-qubes-task-manager-1.0-1.x86_64.rpm is not trusted. Failing package is: 3isec-qubes-task-manager-1.0-1.x86_64
Try to add ‘–enableplugin=expired-pgp-keys’ to resolve the problem. Note: This plugin might not be installed by default, as it is part of the ‘dnf-plugins-core’ package.
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing ‘dnf clean packages’.
Error: GPG check FAILED
rpm --import /etc/pki/rpm-gpg/RPM-GPG-KEY-unman ?
