ohno
September 9, 2021, 5:39am
1
I was going to use StealthVPN, but StealthVPN requires Astill software to run. How do I configure in Qubes to provide networking for virtual machines. Although openvpn is the best choice, openvpn is not available in my region.
Johnboy
September 9, 2021, 6:17am
2
You can find a documentation to setup a VPN gateway here:
How To make a VPN Gateway in Qubes
<div class="alert alert-info" role="alert">
<i class="fa fa-info-circle"></i>
<b>Note:</b> If you seek to enhance your privacy, you may also wish to consider <a href="/doc/whonix/">Whonix</a>.
You should also be aware of <a href="https://www.whonix.org/wiki/Tunnels/Introduction">the potential risks of VPNs</a>.
</div>
Although setting up a VPN connection is not by itself Qubes specific, Qubes includes a number of tools that can make the client-side setup of your VPN more versatile and secure. This document is a Qubes-specific outline for choosing the type of VM to use, and shows how to prepare a ProxyVM for either NetworkManager or a set of fail-safe VPN scripts.
Please refer to your guest OS and VPN service documentation when considering the specific steps and parameters for your connection(s); The relevant documentation for the Qubes default guest OS (Fedora) is [Establishing a VPN Connection.](https://docs.fedoraproject.org/en-US/Fedora/23/html/Networking_Guide/sec-Establishing_a_VPN_Connection.html)
### NetVM
The simplest case is to set up a VPN connection using the NetworkManager service inside your NetVM. Because the NetworkManager service is already started, you are ready to set up your VPN connection. However this has some disadvantages:
- You have to place (and probably save) your VPN credentials inside the NetVM, which is directly connected to the outside world
- All your AppVMs which are connected to the NetVM will be connected to the VPN (by default)
This file has been truncated. show original
regarding StealthVPN:
Looks like you have to download their proprietary client here:
https://www.astrill.com/download/linux
My guess would be to create a test VM, install their client, configure it, and try a second VM to use the first one as a gateway.
Plexus
September 9, 2021, 10:20am
3
Why do I hear the robot from Lost in space inside my head saying “Danger Will Robinson… Danger”! ??
