Kind of had a hard time getting bluetooth running despite there being quite a bunch of guides and problem-reports on the internetz. Or maybe because of that. As usual I found the arch wiki most helpful.
There is a guide for debian qubes somewhere which was helpful, but I wanted to use pipewire and debian being the old aunt…
Anyway, I’d like to share my writeup, since that might be useful for others.
### in dom0
# check and/or enable bluetooth controller
cat /sys/devices/platform/thinkpad_acpi/bluetooth_enable
echo 1 > /sys/devices/platform/thinkpad_acpi/bluetooth_enable
# you can try to persistently attach the bluetooth controller
# but the device ID (check which) might change after a reboot
qvm-device usb attach --persistent podcasts sys-usb:1-7
### in templateVM
# archlinux, obviously
sudo pacman -S bluez bluez-tools bluez-utils blueman
sudo pacman -S pavucontrol pulseaudio-bluetooth linux-firmware
sudo pacman -S obs-studio
# enable experimental features for bluetooth
sudo nano /etc/bluetooth/main.conf
# put the following just under [General]
FastConnectable = true
Experimental = true
KernelExperimental = true
### in appVM
# to be done once if you want to make bluetooth configs persistant
sudo cp /etc/bluetooth /rw/config/
sudo /bin/sh -c 'echo "mount --bind /rw/config/bluetooth /etc/bluetooth" >> /rw/config/rc.local'
sudo /bin/sh -c 'echo "mount --bind /rw/config/bluetooth /var/lib/bluetooth" >> /rw/config/rc.local'
# to be done after each reboot (after attaching the usb-bluetooth-controller)
rfkill list
sudo systemctl start bluetooth
pulseaudio -k ; pulseaudio -D
# play around with stuff
blueman-manager&
pavucontrol&
quake2&
I couldn’t get pipewire to work, though. Which is unfortunate as modern bluetooth headsets rely on modern codecs. To use a recent kernel in your archlinux qubes this is how-to it.
I’m happy for anybody correcting mistakes in my writeup… and for relevant advice concerning pipewire of course. I assume the qubes devs are working on it.
PS: this looks promising.
