here is what i need to do, make notes. so screenshot an area of a pdf or webpage, which is running in the same vm as notes, and then put it into the note taking application
But i cannot do this, i tried instlaling flameshot in work vm, but got a message, that the vm tried to create a very large window, because i am using multiple monitors
i tries intalling flameshot in dom0. and while i am able to at least take a screenshot, pasting it into another vm becomes problematic. I clicked copy to clipboard then tried the same ctrl sfhit v and ctrl v in the respective note vm
didnt work
So is there a way to make it work, anything is fine for me, within the same vm or from dom0.
Thanks,
