Hi everyone.
I’m am in a situation where I need to probably disable usb:
- AUTOSUSPEND and/or
- power/Control
Either from the dom0 and/or sys-usb (USB vm).
I have a windows android software that requires to be initialized via android “BROM_MODE” or “Mediatek Preloader” when the phone is off using volume combinations while inserting the USB cable for the software to initialize. I have used the same software on a windows10 installed laptop without QubesOS and with worked seamlessly.
At the moment I am trying to use the same software in Windows10-StandAlone-VM on Qubes but I am having issues with usb being automatically disconnected from BROM_MODE, then powering the android phone after the device is being detected by the Android software installed in Windows10-StandAlone-VM but this is not supposed to happen. I have disabled the power control option in the Windows10-StandAlone-VM on Qubes but didn’t solve the problem.
After some troubleshooting, I discovered that this is probably caused by the USB AUTOSUSPEND, AUTOSUSPEND_TIMEOUT_MS, power/control and/or power/level configuration in the /sys/bus/usb/Devices/ directory either in the sys-usb or dom0 vm.
I have I changed my disposable USB to a stand-alone us so as to contain the configurations.
I have tried couple approach that I discovered online such as:
- Updating the /etc/default/grub file with coreusb.autosuspend=-1
- Creating USB Udev rules to disable power/control by set to auto
- Using: powertop, tlp and hub-ctrl
None seem to be working at the moment.
I also noticed that in the /sys/bus/usb/Devices/ the external input device configurations are disposable after removal and they are symnlinked so, I can’t update the power/ configurations for inputted usb device individually because it will be discarded and replaced to default configurations after I remove and input the USB again.
I don’t know maybe it’s the sys-usb or dom0 that is responsible for the AUTOSUSPEND and power/ configurations.
I appreciate all your supports to resolve this issue.
Thanks.
