Hello, I am asking for help to uninstall qubes os, as i no longer wish to use this operating system. im looking to switch back to windows. could someone tell me all i need to do?
You shouldn’t have to do anything special. When you go to install Windows, simply target the storage device on which Qubes was installed, and the Windows installer should take care of everything for you.
(If, for some reason, you run into trouble, you can simply use any utility to wipe the drive on which Qubes was installed. There are thousands of pieces of software that can do this, and many are included in common software suites and operating systems that you may already have. Try searching the web for “how to reformat a drive” or “how to wipe a drive” for specific examples.)
You don’t uninstall it; you just over-write it with another operating system.
Thank you all, problem resolved. help was much appreciated
