On 4.2.4 (still), I have been retrying without success the procedure described in:
The part ‘Reverting sys-gui’ however seems incomplete to me because even after it, and after manually deleting /etc/qubes/policy.d/50-gui-sys-gui*, I still see quite a few remnants:
Looking e.g. at the content of 30-qubesctl-salt.policy, I see initial warning that the file must not be edited manually. Strangely, there are way too many lines mentioning qubes that don’t even exist (sys-gui-gui only one of them). Etc.
So, is there a more up-to-date correct and complete cleanup procedure?
sys-gui-gpu didn’t work for me either and had to do a fresh install.
It seems to me that to revert all those changes made by the salt scripts, you’ll have to go through the .sls files at /srv/formulas/base/qubes/.
You should be able to see which qubes were created, which features were set, and which configuration files were modified.
It’s easier for me to just re-install and not waste a day trying to fix everything.
Just for information, were there problems of things not working when using a “standard” Dom0 guivm, after following the removal instructions?
…or is it more a problem of residual cruft, referencing deleted gui qubes? (which isn’t desirable, but would only cause problems if the qube name(s) get used again)
Thanks @Privacc . Did you only do “fresh install” because it was easy, and not because Dom0 gui got broken?
I was asking anyone who tried it, because I did not remember seeing any problems after removing the guivm (sys-gui, not sys-gui-gpu)… but it was not recently.
I had to reinstall because after setting up sys-gui-gpu, the desktop was crashing on startup.
I troubleshooted for several hours unsuccessfully, and then reinstalled.
Just for information, were there problems of things not working when using a standard Dom0 guivm, after following the removal instructions?
None for me, at least nothing visible, except the annoying reminder that I must update the Fedora template of the GUIVM.
