I have an intermittent problem with sys-usb not starting up on boot.
(I’ve checked - autostart is indeed ‘True’).
This is not the end of the world, since I’m working off a laptop, but its an inconvenience, an extra layer of ‘stuff’ after quite a long boot-up.
I thought I could maybe add a line to an autostart file somewhere in dom0: if sys-usb has started properly already, the command will do nothing (I think); if sys-usb hasn’t started, it would fix that.
But I don’t know what command that would be. The documentation talks about
$ qvm-run <VM-NAME> <COMMAND>
where COMMAND refers to an application. But trying without
$qvm-run <VM-NAME>
does nothing. I thought about maybe starting terminal, then closing it with
I’m probably missing something simple. Anyone point me in the right direction?
