I always use whonix gateway. However, Tor IPs are often blocked.
So I want to combine a VPN after Tor, but I don’t know how to do it in Qubes. Qubes is different.
If anyone has already done it, please let me know.
set your sys-vpn as netvm for sys-whonix. In dom0 terminal:
qvm-prefs sys-vpn netvm sys-whonix
And connect through sys-vpn. But i don’t think you could use torbrowser like that.
Thank you Tezeria. By chance, I was looking for a way to use SYS-Whonix and VPN communication at the same time and found this thread. My torbrowser worked fine this way.
What’s the point of setting sys-vpn as netvm for sys-whonix if he wants to set vpn over tor set-up? In this case vpn should be after tor, not before it. He wants to connect to tor then tor should connect to the vpn and this vpn should be as the “exit node”. In other words: 1st tor node + 2nd tor node + 3rd tor node + vpn > Internet
I think in this scenario he should create vpn qube, configure it and set sys-whonix as its netvm.
yes you’re right: Sorry i missunderstood. My bad ![]()
