You say you have the “exact same error” but you dont tell us what
command you have run or what the error is.
(The error you say you have relates to an unencrypted drive. That cant be the same as yours.)
Tell us exact;y what you have done and exactly what error you
see.
Yes.
What I’m trying to do though, is setup the qubes to work with or without the VC encryption engaged.
If I can setup the qube to run on an external hd vm-pool that gives me the flexibility for the architecture I’m going after.
