When I first used tor, I connected directly without a bridge, but now that I need a bridge, I want to set one up.
Where do I set it up? sys-whonix?whonix-gw?
you should be able to find the answer here:
Simplest way I’ve found is to open the Tor Control Panel in sys-whonix and select “Configure” under the Control tab.
Thank you!
